Vacuum Cleaner Help Forum
Adding brush control to a DC07
All about floor cleaners, vacuum cleaners, polishers etc. for all leading brands, Miele, Dyson, Hoover, Sebo, Electrolux, Numatic and all others. For vacuum cleaner spares, bags etc. click here
Get vacuum cleaner spare parts
Buy vacuum cleaner spare parts in our store for vacuum cleaners with many low cost compatible spares available or contact us and we will find the parts you need for you
by Pistol » Mon Apr 03, 2006 2:12 pm
Hi there,
Odd little problem here. We were given a Dyson DC07 vacuum cleaner as a wedding present, and presently it's doing a fine job of cleaning our carpets. However, we're getting a lot of redecoration done at the moment, including some fancy carpet in the hall and back bedroom which can't be vacuumed by a cleaner with a brushbar! As well as laminate flooring in the back room which can't be done either!
Since you can't stop the brushbar on the DC07, I am shortly to be left with a vacuum cleaner that can only be used in two of the seven room of the house. That's not much use! Should have got the brush control model, I know...
What I would like to know is whether the brush control assemblies are the same - i.e. could I buy the brush portion from another model and fit it to my DC07? I've got my eye on the front assembly from a DC04 which I'm assured by the seller will fit, but then they would say that eh!
Pistol
by Goatboy » Mon Apr 03, 2006 3:54 pm
Not a DC04 to a DC07.
But (in theory) you could get a DC07 head, with clutch, and fit it. Though it would be an awkward job.
Lancelot wrote:Despite your aspersions on my abilities... you're still my hero!
Goatboy
by legsthediver » Mon Apr 03, 2006 9:41 pm
using second hand parts IF available.. If you brought it to MY shop.. it would cost approx £40-£50.. Which is reasonable for the amount of parts and labour required.. to back up lasy message, the dc04 bits (apart from clutch) will NOT fit.. Good luck..
legsthediver
Regular Forum User
Regular Forum User
by Pistol » Tue Apr 04, 2006 9:29 am
Well I've found someone who says he can supply a complete head assembly, so I guess it depends on my ability to disassemble and reassemble that part of my Dyson without losing a myriad of tiny parts under the sofa :)
I think I'll have a go at taking off all the user-servicable parts first, to give me an idea of the complexity of the task. Might as well take the opportunity to clean the filters!
Any advice on disassembling a Dyson head? (Beyond unplugging it first obviously!) If it looks too frightening to proceed further than removing the user-servicable parts, I guess I can always take it to a repairs shop to get it done.
Pistol
by Goatboy » Tue Apr 04, 2006 11:08 am
They're full of tiny little torx screw. But somebody at Dyson, realised that everyone has adaptors for torx screws. So now on the DC07, these screws are at the bottom of narrow deep shafts, so you can't get your adaptor in there :( and you'll need to buy the correct screw-driver!
Saying that, there's only one of these unacessible screws on the clutched head. Taking your old un-clutched one off should be easy :D
Good luck, and let us know how you get on :tup:
Goatboy
by Pistol » Tue Apr 04, 2006 12:12 pm
Cheers!
I've found some extremely useful information on Dyson maintenance over at www.dyson-online.com - I'm pretty confident I can handle the disassembly and reassembly now (provided I don't lose the screws ;) )
I'll report back when I've had a go - I can't be the first to realise I need brush control after all, and £40 for the parts is pretty reasonable compared with the cost of replacing one Dyson with a new one!
I guess the only drawback would be that if I make an obvious hash of it my warranty will be void.
Pistol
by Pistol » Tue Apr 25, 2006 8:32 am
Well, just to let you know, I did it successfully :) I now have a Dyson I can use all over the house.
There's a great exploded diagram of the two types of head assembly over at espares, hope they don't mind if I link to it. The parts I ordered were:
Cleaner head assembly (1)
Brush housing assembly (6)
Clutch actuator outer (7)
Clutch Assembly (8 )
Clutch Cover (10)
Brushroll Assembly (12)
Soleplate Assembly (13)
I managed to get a combination of new and second hand parts, total cost was under £40.
Using the information at Dyson-online's technical advice pages it was pretty straightforward to work out how to disassemble the old head and reassemble the new one.
I'm still not convinced that a DC04 head wouldn't fit on a DC07 - I'm certain that many of the parts I received were actually DC04 parts, and they all fitted together fine. I'm loath to recommend anyone to go out an buy a DC04 head in case I'm wrong, but given that I could have bought a complete DC04 head for £10 or so (!) I do wish I'd given it a go myself - if it didn't fit I could have just ordered a couple of new DC07 parts rather than the whole lot, and the total would still have been less than I paid in the end.
Can't complain though - in all, it was a lot cheaper than a new vacuum cleaner!
Pistol
Return to Vacuum Cleaner Help Forum
