by NickStranger » Sun Aug 05, 2012 8:57 am
Built in fan assisted oven. About 8 yrs old.
It works for bit then cuts out and it's got a funny smell. I changed fuse on Friday and it was working but it's gone again today.
Any ideas? Worth fixing?
NickStranger
- Appliance Forum User
by kwatt » Sun Aug 05, 2012 9:10 am
A make and model would help Nick.
But it does sound like a problem with the cooling fan or fan control thermostat.
by NickStranger » Sun Aug 05, 2012 9:20 am
Electrolux E0B 944
NickStranger
by NickStranger » Sun Aug 05, 2012 10:06 am
Here's a pic of the label on by the door, with the model and PNC:
http://imgur.com/ZrUrDHope this helps.
Have found on another page that it might be the Thermal Cut Out unit. Should I give it a go replacing it?
NickStranger
by kwatt » Sun Aug 05, 2012 10:25 am
Okay, found it.
There's a cooling fan and a fan control stat in that model, that's it really for that side of things.
It's possible that it's the thermostat that's the problem but the symptoms you describe are more consistent with the cooling fan failing or failed and the thermostat doing its job and shutting the oven down.
The cooling fan is here so you know what to look for:
http://shop.ukwhitegoods.co.uk/Cooker+% ... Motor.htmlHTH
by NickStranger » Sun Aug 05, 2012 10:28 am
Thank you.
Is the cooling fan easy to replace myself???
NickStranger
by kwatt » Sun Aug 05, 2012 10:30 am
Not too bad to do I shouldn't think.
by NickStranger » Sun Aug 05, 2012 10:32 am
Where roughly on the oven would it be? Would it be as simple as it would be to change that Thermal cut out unit, ie pull it out a bit and take the top off??
NickStranger
by kwatt » Sun Aug 05, 2012 11:02 am
Pretty much, yes.
by NickStranger » Sun Aug 05, 2012 11:07 am
Thanks for the advice.
Have ordered and will report back.
NickStranger
by NickStranger » Sat Aug 11, 2012 4:18 pm
Hi.
I ordered the cooling fan and installed it, and although the outside of the unit is cooler now, it is still cutting out after 15-20 mins.
Any ideas???
NickStranger
by r600a » Sat Aug 11, 2012 8:23 pm
There is a thermal cut out which has 2 white wires and 2 blue wires that are in a plastic tube normally on the left middle towards the front. This will have normally failed if the fan had previously gone. It senses the temprature and cut off if it gets too hot or thinks it has.
Bryan
r600a
- WTA Team Member
by NickStranger » Sat Aug 11, 2012 8:34 pm
r600a wrote:Hi
Bryan
Thank you.
Do you have a link to a product I can order???
NickStranger
by r600a » Sat Aug 11, 2012 8:46 pm
I' in the middle of no where at the moment with just my phone but I'm sure ken could find it for you.
Bryan
r600a
- WTA Team Member
by NickStranger » Sun Aug 12, 2012 8:11 am
r600a wrote:I' in the middle of no where at the moment with just my phone but I'm sure ken could find it for you.
Bryan
Any ideas Ken?
NickStranger
- Advice needed regarding a new gas hob
by marmot » Mon Nov 03, 2008 5:38 pm
- 559 Views
- Last post by helo_75
Mon Nov 03, 2008 7:15 pm
- Oven and Hob Advice Needed
by benmc » Thu Jul 17, 2003 8:22 pm
- 2032 Views
- Last post by Del
Fri Jul 18, 2003 8:51 am
- Oven not working - advice needed
by acemonkey » Sat Feb 25, 2012 3:46 pm
- 300 Views
- Last post by jimca007
Sat Feb 25, 2012 9:48 pm
- Electrolux EOG 660 gas oven tripping MCB
by ericthelobster » Tue Jul 11, 2006 12:33 pm
- 9 Replies
- 1407 Views
- Last post by wsts
Mon Jul 17, 2006 12:13 pm
- Diplomat gas oven problem, advice needed.
by welshsue » Fri Mar 31, 2006 5:24 pm
- 930 Views
- Last post by gegsy
Fri Mar 31, 2006 6:51 pm
Users browsing this forum: alro and 11 guests
