I have a Zanussi ZWF1650F. Initially wash programs would not complete. Using the diagnostics features intial errors where reported as varying between E52 and E34. E52 supposebly indicating tacho errors. I tookk the motor off, reviewed the brushes, approx 40mm remaining. Took the tacho off, magnet looked fine. For the sake of it I switched the brushes over.
After re-fitting the motor diagnostics then started for the first time reporting E66 errors, and now supposebly a heating element or pcb error. I made OL tests of the heating element, found no leakage. I then finally went for a review of the main PCB. Found a burnt PCB. Ordered a replacement pcb, arrived today, fitted it. E66 errors still be reported, and the only diagnostics tests not now failing with E66 alarms are 'DRAIN' and 'DRAIN & SPIN".
Thanks,
