Asko Asea table top model 750
by anzaniman » Fri Jul 01, 2005 3:32 pm
The door spring on my dishwasher has broken, where can I obtain a replacement.
Arthur Montague
anzaniman
 Dishwasher not draining?
If your dishwasher will not drain the cause will often be that either the drain pump is blocked or faulty resulting in the dishwasher failing to empty. You can buy replacement drain pump including many low cost compatible dishwasher pumps in our store here to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Drain pumps for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, LG and many more
by alexa » Fri Jul 01, 2005 11:54 pm
Where do you reside?
alexa
Valued Contributor
Valued Contributor
by Bill » Sat Jul 02, 2005 8:56 am
pressure spring, door part number 80 529 77 around the £2.50 + vat and postage. Availablity one to two weeks :roll:
Bill
Bill
Valued Contributor
Valued Contributor
by Washman » Sat Jul 02, 2005 12:09 pm
HI ALL
Bill are you sure this is correct spring part number as I have just looked in my ASKO service manual for 750 dw and it shows door spring as p no 7840019 and calls it lid brake spring this also comes up on Connect under this part number .
Washman (mike)
Washman
Valued Contributor
Valued Contributor
by Bill » Sat Jul 02, 2005 12:23 pm
velly intresting my manual does not show for that model so looked at simular machine 760
Bill :oops:
Bill
Valued Contributor
Valued Contributor
by Washman » Sat Jul 02, 2005 12:35 pm
Hi Bill
The 750 is the original machine that was also sold as an Ariston for a while can't remember mod no . This one DW 750 has the door that pops open at the end of the cycle so is getting on abit . the manual is dated 1986-08
I have manuls for lots of older Asko /Asea machines.
Mike
Washman
Valued Contributor
Valued Contributor
by Bill » Sat Jul 02, 2005 3:08 pm
Thanks Mike I will remember that.
Bill
Bill
Valued Contributor
Valued Contributor
by anzaniman » Sun Jul 03, 2005 7:12 pm
I live in South Oxfordshire.
This is an early machine (which replaced our very aged Colston) but I think its only about 10-12 years old.
The spring required is one of 2 that support the door, which does open at the end of a cycle.
Look forward to your response.
Regards, Arthur
anzaniman
 Dishwasher leaking?
If your dishwasher is leaking one of the most common reasons is that a door seal is faulty allowing water to escape. You can buy replacement door seals in our store here to fit all major makes including Lamona, Beko, Hotpoint, Bosch and many more
Door seals for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
