by donduelan » Thu Aug 10, 2006 10:21 am
Hiya folks..Well what a great site.
Well I have been having an ongoing( past month or so) problem with my F&P501. During a wash cycle it would stop beep constantly and display 00010000. You could sometimes advance the cycle and it would work from there.
On looking at your site I entered the diagnostics (I didnt get the 2 beeps after pressing power and wash temp) and got the following code 10000001. I looked at your site further and had a little bit of a play. Checked switches etc. All seemed ok. Now the machine want stop at the required fill level and seems to be completely out of sorts. The error code I get now is 100000011. I am wondering if anyone has any ideas and could of of upset its programming while trying to get into diag?
Any help would be great...its an oldy but a little longer would be handy!!
donduelan
by bigsmokepiker » Fri Aug 11, 2006 10:57 am
Last fault code indicates RPS(Rotor postion sensor)
But typical of this model may be Motor controler.
Also with 501 ( 9-10 Year Old) I would check underneath machine
for signs of leaks
What can happen ? Seal gives way & leak onto to motor area ( Where RPS Is located ) Water can corrode contacts at RPS .Giving this fault Code. If So New Machine ( IE Means , Main Seal Bearings Main Shaft, RPS, Maybe Stator
Best Case RPS ( $45_ $50 Aus)
bigsmokepiker
- F&P 051 problem
by AnjaMc » Wed Jan 24, 2007 6:38 am
- 1039 Views
- Last post by AnjaMc
Sat Jan 27, 2007 11:44 pm
- Problem GW701
by Guest » Mon Jul 25, 2005 3:25 am
- 10 Replies
- 3176 Views
- Last post by KiwiwantsworkinCanada
Wed Jul 27, 2005 6:58 pm
- F&P GW611 Problem
by chrisgoodwin » Sun Nov 27, 2005 6:04 am
- 11 Replies
- 2452 Views
- Last post by sudeep
Wed Feb 20, 2013 11:36 am
- Smartdrive 600 problem
by Steelo » Sun Jan 28, 2007 7:26 am
- 925 Views
Sun Jan 28, 2007 1:12 pm
- Problem with P & K smartdrive 703
by mibbetson » Mon Nov 05, 2007 2:37 am
- 1205 Views
Mon Nov 05, 2007 11:51 am
