by Neilo » Mon Oct 24, 2005 10:56 pm
Hi All. This one is filling in bursts before fault codeing.
Fault code is
10000011 (Long Wash, Final Rinse, Spin)
Can ayone tell me the fault code number and what it means?
Thanks heaps!
Neilo
- Appliance Forum User
by Penguin45 » Mon Oct 24, 2005 11:16 pm
Assuming your diagnostic code to be correct, this is actually to do wth the drive motor. The rotor position sensor is faulty, the wiring is faulty or the module itself is faulty.
We've had a few of these lately, check down this forum for more info.
Power off if going inside.
by Neilo » Tue Oct 25, 2005 12:11 am
Thanks Penguine!
I've read quite a few including the one about the rotor sensor, presume its down near the smartdrive? Don't think it is the out of balance switch, seams to be working fine. Replaced the two valve inlet units already and a new lid. Had to Adjust the lid reed switch in the controller just a bees dick because it wasn't engaging properly with the lid closed. It is now.
The fill problem is intermitent, persistantly trying to run the machine will eventually get it to work and often it will then run a number of loads. Going back to it the following day and it will do it again. Does this tell you anything that could narrow the fault down a little?
Brgds,
Neilo
Neilo
by Neilo » Tue Oct 25, 2005 3:10 am
Hi Again Penguin
Just checking I am giving you the right ldiagnostic Led's. It is the Long Wash, Final Rinse & Spin leds that remain constantly lit when the beeping starts. Total of 8 leds across the top of this model so if Spin=1, Final Rinse=2 & Long Wash= 8 the error code is 11?
Thnks again for all your help, this is such a great site!
Neilo
by Neilo » Tue Oct 25, 2005 9:53 pm
My email address is
neil@nco.com.au
Neilo
by Penguin45 » Wed Oct 26, 2005 12:49 am
Nice try! Your code is 1 +2 +128 (!) = 131. This is a motor circuit fault. I can't tell you much more - Kiwi and FastandPro will pick up on this when the world turns round far enough, so stand by......
by FastAndPro » Wed Oct 26, 2005 2:14 am
Its a sensor problem normally.
Try the contacts on thr rotor Possition sensor. Perhaps a bit dirty
look for any rust marks and leakage on the motor its a sign of bearing problems not so common on the 600 or 700 machines as they used better stuff back then.
FastAndPro
- Regular Appliance Forum User
by Neilo » Wed Nov 23, 2005 5:42 am
Hi Guys
Sorry for the late reply, have been away. Kiwi was right on the money, it was the RPS. Thans to him and Penguin - fantastic site guys!
Neilo
- F & P smartdrive 501 Washing Machine
by chauscon » Sun Nov 13, 2005 12:17 am
- 6 Replies
- 2272 Views
- Last post by FastAndPro
Thu Nov 24, 2005 1:17 pm
- Candy Washing Machine.
by zamiac » Tue Dec 20, 2005 12:44 pm
- 6 Replies
- 2291 Views
- Last post by Martin
Fri Dec 23, 2005 8:05 am
- F&P GW708K washing machine
by kiwilost » Sun Dec 23, 2007 8:20 am
- 933 Views
Sun Dec 23, 2007 8:39 am
- F&P Washing Machine MW053-K
by MikeyU » Sun Jul 25, 2010 4:54 am
- 959 Views
- Last post by greasylightbulb
Mon Jan 31, 2011 8:48 pm
- F+P 051, Phase 1 Washing Machine Error
by deangc » Fri May 25, 2007 12:13 am
- 1112 Views
- Last post by bigsmokepiker
Fri May 25, 2007 7:53 am
