I have a ~10yr old Fisher and Paykel GW603-U
I have followed the instructions to get it into diagnostic mode -
ie. Hold "Wash Temp Down", then press "Power". Wait for the two short "beeps", Toggle the "Spin" buttons until "Hold" and "Slow Spin" lamps are lit.
If there is a fault, it will now be displayed on the wash lamps across the top of the control panel.
To read any code displayed, start at the right and note which lamps are lit. It's a binary code; ie : 1+2+4+8+16+32+64+128. Add up the ones which are lit to give the last fault code.
Unfortunately when I hold "Wash temp down" and then press "Power" (switching the machine on) all the lights on the panel light up for about 5 seconds, there are no beeps, and then the machine just displays the high and low water level lamps and nothing else.
If I then select the spin speeds "Hold" and "Slow" no more lights come on the top panel - am I doing something wrong?
Once when I did this and then powered off again, the 5 left lights in the top wash section went on even though the machine was off.
I have noticed that whens I try to goto diag mode, if I then hit hot or cold water again, it pours water into my machine (hot or cold) - similarly if i hit spin the red spin light comes on and the machine seems to be pumping water out of the bowl (but does not spin)
The actual problem I have is that when I put the clothes and detergent into the machine, power on and select the wash I want (say regular) - all the lights are displaying as usual but nothing happens when I press start - other than the leftmost wash light stopping blinking, but the machine doesnt start.
The machine was doing this a few weeks ago and then for no apparent reason started working fine again - now its stopped working again and I can't get it go.
Please help!!
