by wjbrambley » Fri Apr 16, 2010 12:41 pm
wbrambley wrote:Hi, what does the short wash, second rinse light and the spin light mean in diag mode? Machine has been stopping during a cycle almost as if its software had hung Now it will only fill for a second and stop. Starts filling for another second and stop. then from what i can tell it goes into diagnostic mode by itself.machine is a gw503k. Any help would be great as it is only a matter of time before i pull it down bit by bit.
Sorry about that, from right to left they are: on,on,off,on,off,off,off,off. thanks.
wjbrambley
by Penguin45 » Sat Apr 17, 2010 12:11 am
11 - pressure sensor error. This is the water level control switch and it's integral with the main pcb.
Try:
Pulling off the air hose and ensuring that it's not blocked, nipped, trapped or holed in any way. If that doesn't do it, the pcb is the culprit.
by daw_z » Mon May 03, 2010 2:32 am
Glad I found this forum...
I have a SmartDrive9 Pride 5.5 with the following error code:
Off, Off, ON, ON, ON, ON, ON, Off.
Any help would be greatly appreciated. (Guessing new pump needed, but i wouldnt have a clue!!)
daw_z
by bigsmokepiker » Tue May 04, 2010 6:46 am
Fault code 62 (Pump Fault over current) can also come back to Motor Controller
bigsmokepiker
by Nasty » Sun May 09, 2010 4:06 am
Hi there,
Great Forum by the way.
I have a SmartDrive 9 5.5 as well.
MW059AU
Error codes are
off off on off on off on on
Thanks again.
Nasty
by bigsmokepiker » Mon May 10, 2010 3:47 am
Fault Code 43 OOB Switch Fault
Numerous Threads For The Fault Code
bigsmokepiker
by Nasty » Tue May 11, 2010 8:00 am
ok replaced the switch and all good. But.....
Next error I get is
off off on on off off on off
Thanks guys.
Nasty
by bigsmokepiker » Wed May 12, 2010 6:46 am
FAULT CODE 50
Hot water valve fault
Check connections to hot water valve
Could be faulty Valve itself
Have you got the tap turned on? to hot water
bigsmokepiker
by versatech7 » Fri May 28, 2010 8:42 am
Hello all, new to this forum thing but here goes.
Inherited a GW712 with the house and it goes straight to 0 1 0 0 0 0 1 0 on power up with constant beeping.
I'm able to get it into DMode by holding the "wash temp down"+"Power" button then switching on mains, two beeps then toggle spin buttons to get "slow" and "spin" lamps lit. Same code as above.
I believe from what I've read this is a "66" code relating to the pressure switch and needs to have the motor control module replaced?
Was able to get the bowl pumped out by applying pressure via tube to sensor (it actually did a small cycle so I set it to a full load).
Am I up for a new controller or is there any thing else I can do.?
This is a legendary site. Thanks.
versatech7
by versatech7 » Fri May 28, 2010 10:39 am
Further to the above, thinking that I was on my way to a less than $100 fix on my 708 (have one of these that I thought had shot bearings), I've just pulled that apart (708) and the hub of the stator is actually breaking up, causing the stator to go off centre and contacting the magnets in the rotor.
This machine is 13 years old and has had a flogging, it wasn't going to last forever. The rest of the machine is in very good condition, although some of the plastic has had a lot of stress from a couple of OOB issues over the years. I'd buy another one in a heartbeat.
Don't think it would be worth fixing though as a new stator would be worth $$$$$ I expect.
Oh well, nothing lasts forever.
Simmo.
versatech7
by minds » Thu Jul 15, 2010 10:45 pm
Hi there I have a Fisher and Paykel Pride with the following from right to left
off on off off off off off on
if left to right at the console it would be the first light (long wash) and the second to last light between rinse and spin
stops and starts goes one minute surges the next then bleeps
any info is good
minds
minds
by Desailly » Sun Jul 18, 2010 10:14 am
Thanks for such a helpful forum.
I have a F&P smartdrive GW709AU with the following error sequence (right to left):
on, on, off, on, off, on, off, off
Would appreciate advice on what the error code is and if it might be something I could fix myself or if I'll need to get a technician in.
Thanks.
Desailly
by Desailly » Sun Jul 18, 2010 10:57 pm
Hi - after reading through the posts in a bit more detail I think I've figured out the error is 43 - balance switch. I would like to attempt to replace it myself if it's not too difficult. I've done an internet search for the part and it seems you can buy generic ones much cheaper than the F&P ones. Are the generic ones OK to use? Anyone had any problems with them?
Desailly
by bigsmokepiker » Tue Jul 20, 2010 4:39 am
Can use these Micro switches no drama
bigsmokepiker
by elks4 » Mon Aug 09, 2010 9:25 pm
I have a problem with my fisher & paykel washer model GWL03. it powers up but will not start. I went into diagnostic mode:
lights for slow/hold spin mode are from left to right: on off off off off off on on
If I am reading them correctly the error code is 193 or 131 depending on how it is read?
Can anyone help me.
If I have entered the wrong forum or am violating any protocol please forgive me as I am new to this kind of thing.
elks4
- Fisher & Paykel MW511 Error Codes
by greatant » Wed Dec 16, 2009 7:21 am
- 2446 Views
- Last post by patrick_kiwi
Sat Jun 19, 2010 2:03 am
- Fisher&Paykel GW611 Washer error codes.
by GWH » Thu Sep 22, 2005 6:17 am
- 11 Replies
- 4404 Views
- Last post by GWH
Wed Oct 05, 2005 9:38 am
- Fisher Paykel MW511 multiple error codes
by jommoner » Sun Dec 06, 2009 8:10 am
- 1619 Views
- Last post by jommoner
Tue Dec 08, 2009 6:22 am
- deciphering Fisher and Paykel Smartdrive error codes
by patrick_kiwi » Sat Jun 19, 2010 2:10 am
- 1166 Views
- Fisher & Paykel GW708U Washing Machine Error Codes
by oxybeles » Fri Aug 17, 2007 2:19 am
- 4 Replies
- 3140 Views
- Last post by DIYHAZARD
Sun Mar 30, 2008 3:15 am
