by Penguin45 » Wed Feb 01, 2006 12:14 am
You rang?
I think you'll find that this is the water level control system playing up. With the machine empty and the power off, check that the tube from the airbell at the bottom of the tub to the level switch is not trapped, kinked trapped or holed or contains water. Blow clear if so.
Slight possibility of electronic board failure, but this is unusual.
