by ledfootrob » Sun Jul 22, 2007 6:25 am
i turned my washing machine on today and it just started beeping at me and showed these lights 0 0 1 1 0 0 0 1 code (49) i believe
From what I have read in other threads about this - the cold water solenoid is faulty. I checked both the coils and they both read about 60 ohms. What else can i check, are those readings ok??? Any help much appreciated.
ledfootrob
by Penguin45 » Sun Jul 22, 2007 8:35 pm
Valve should read 64ohms, so you're pretty close. Wiring harness may have dirty/oxidised/displaced connectors (common); there may be an actuation problem on the PCB.
by ledfootrob » Mon Jul 23, 2007 1:29 am
ok i had a look pulled it all apart seems clean etc. i pulled the plug off goin to the water solenoids should i get some sort of reading off the board when its turned on cause the multimeter is showing nothing at all.
ledfootrob
by Penguin45 » Mon Jul 23, 2007 8:18 am
Up to 24vDC for the cold valve.
- MW511 Error on power up (00110001)
by Planky » Sun Apr 22, 2007 5:37 am
- 7 Replies
- 3493 Views
- Last post by fabnz
Mon Apr 26, 2010 8:40 am
- Fisher & Paykel MW511 Error Codes
by greatant » Wed Dec 16, 2009 7:21 am
- 2372 Views
- Last post by patrick_kiwi
Sat Jun 19, 2010 2:03 am
- Fisher Paykel MW511 multiple error codes
by jommoner » Sun Dec 06, 2009 8:10 am
- 1584 Views
- Last post by jommoner
Tue Dec 08, 2009 6:22 am
- Fisher & Paykel MW511 washing machine with error code 28
by ozzman1au » Thu Jan 11, 2007 5:35 am
- 1196 Views
- Last post by ozzman1au
Fri Jan 12, 2007 10:12 am
- Fisher & Paykel MW511 top loader.
by andyreno » Sun Mar 04, 2007 7:45 pm
- 16 Replies
- 3220 Views
Fri Mar 09, 2007 12:37 am
