by jafajones » Mon Oct 30, 2006 8:16 am
We have a F&P washer 601 that has recently developed a fault which results in it restarting the wash cycle after the final spin has been completed. We stop it by hitting stop/pause but when the power button is hit the 3 right lights (rinse, , Spin) come on and the machine can only be switched off at the wall.
Appreciate any thoughts or suggestions
Regards and thanks in anticipation
jafajones
by bigsmokepiker » Mon Oct 30, 2006 9:54 pm
Washer is in recycle feature
To turn off
Turn power at power point. Press &hold Wash temp down button & then power button release buttons after 2 short beeps.
Now Use water level up button to turn recycle feature on/off
Med water level LED ON = Recycle ON
Med water level LED OFF= Recycle OFF
Recycle status can be checked when you Ist turn on washer
If last 3 lights come on =recycle ON
if last 3 lights Off =recycle OFF
bigsmokepiker
by jafajones » Mon Jan 08, 2007 6:44 am
Hi Bigsmokepiker et all, delay in response associated with the washing m/c being at our holiday location and have only just had chance to test your suggestion. (Dec/Jan is our holiday period)
I programmed as suggested, no beep but light pattern changed after approx 2 secs.
Changed Med water level to off per earlier advice.
M/c works fine and switches off as expected as long as power not switched off at wall. If power to m/c lost then reverts to recycle mode and restarts at end of cycle.
Rinse, final rinse and spin lights flash, reprogram as advised and again washer appears to work correctly until power lost for any reason.
This is a holiday place so we will put with the problem - the m/c is probably used 20 times per year however would be great to fix.
Appreciate any advice.
Rgds
Mike
jafajones
- Fisher & Paykel washer smart drive 703
by chrispy185 » Mon Jun 30, 2008 4:41 am
- 1445 Views
Tue Jul 01, 2008 11:35 pm
- Fisher & Paykel smart drive
by keith bolton » Thu Aug 04, 2005 2:55 am
- 1475 Views
- Last post by keith bolton
- Fisher Paykel Smart drive 053
by Muzz » Mon Sep 19, 2005 7:15 am
- 5 Replies
- 2496 Views
- Last post by KiwiwantsworkinCanada
Thu Sep 29, 2005 7:00 pm
- Fisher & Paykel smart drive 051: HELP
by hindonly » Fri Oct 07, 2005 6:59 am
- 1723 Views
Fri Oct 07, 2005 11:38 pm
- Fisher & Paykel smart drive 603
by astro » Wed Nov 23, 2005 5:39 am
- 1748 Views
- Last post by astro
Fri Nov 25, 2005 1:53 am
