I have a F&P GW509AU with an intermittent fault. It will usually run through a full cycle without a problem but occasionally it will get to the end of the rinse cycle and fail to pump out. When this happens the pump does not seem to be getting sufficient power to drain the machine. It starts slowly and runs for a second or so then stops and this cycle is repeated regularly approx 5 seconds later.
I ran the diagnostic test as suggested in other posts after this happened but there is no error code displayed at all. I was able to test the pump while in diagnostic mode and it runs OK and was able to empty out the machine.
I removed the pump to check for anything obstructing it but found nothing. Checked the outlet hose and it also seems to be clear.
Any ideas?
