by fcollingwood » Wed Jul 25, 2007 7:08 am
Just when I thought I'd got the damn thing licked.....
Can anyone tell me what 00101011 (43) means?
fcollingwood
- Appliance Forum User
by bigsmokepiker » Wed Jul 25, 2007 7:15 am
Out Of balance switch fault
Check OOB microswitch (Terminals corrode) Also Check Switch housing pins that hold in OOB Switch Break (Plastic)
Switch located in top console RHS under Motor Controler(PCB)
bigsmokepiker
by Jazz » Wed Mar 05, 2008 12:13 pm
hey there,
Just had the same prob. tried to fix the switch, didnt work. If you want an easy fix just connect the yellow and white wires coming of a 4 pin connector on the right hand side just under the control panel that go to the switch. The machine wont shut off if it gets out of balance but it will work.
Jazz
Jazz
by Penguin45 » Wed Mar 05, 2008 9:13 pm
Safety device - must be replaced at the earliest opportunity.
- F&P Smartdrive GW701 - Error Code Help
by ShaunOverton » Sat May 26, 2007 10:22 am
- 12 Replies
- 2890 Views
- Last post by ShaunOverton
Wed May 30, 2007 10:37 am
- F&P GW701 code 136
by fcollingwood » Mon Jul 02, 2007 7:38 am
- 7 Replies
- 2002 Views
- Last post by fcollingwood
Thu Jul 05, 2007 7:56 am
- F & P GW701 Fault code 214 "11010110"
by sirius0 » Thu Jul 12, 2007 9:08 pm
- 6 Replies
- 1865 Views
- Last post by sirius0
Tue Jul 17, 2007 6:53 am
- Fisher and Paykel GW701-U washer fault code 0010 0101
by radiotech » Tue Jun 13, 2006 10:03 am
- 1036 Views
- Last post by johnmac11
Tue Jun 13, 2006 10:48 am
- FISHER PAYKEL GW711 ERROR CODE 01000010 (code 66?)
by knockabout » Sun Feb 10, 2008 10:40 am
- 7 Replies
- 2152 Views
Sat Feb 16, 2008 5:36 pm
Users browsing this forum: No registered users and 1 guest
