Australasian Appliance Forum
IW810AU pump buzzing
Postby JamoAus » Wed Jul 06, 2011 4:35 am
Hey guys, I'm Glenn from australia, nice to meet ya =)
Somebody on another forum recommended I try asking here..
I have a Fisher and Paykel "intuitive eco" washing machine model IW810AU , and when switch is off, (power point on) drain pump is buzzing. It measures 36 Ohms and works on the bench when removed.
It doesn't work on diagnostic mode using the fabric care button and no fault code comes up.
Any ideas apart from replacing the motor controller?
Glenn
JamoAus
Re: IW810AU pump buzzing
Postby ratbag_359 » Wed Jul 06, 2011 7:06 am
So the machine can't operate it?
And you can turn on the machine and will fill, wash,etc?
Just won't drain?
If that is the case the triac in the motor controller has failed. or the control circuit for the triac has.
ratbag_359
Postby JamoAus » Thu Jul 07, 2011 5:06 am
Hi there,
Yes it does fill and wash, but not drain. During this drain motor continues to buzz. Occasionally the machine will cut out completely and needs a minute or two to reset.
Foud my house voltage to be 253v but when I connect it to my generator (241v) it works fine.
Glenn
JamoAus
Postby ratbag_359 » Thu Jul 07, 2011 6:24 am
That is a interesting issue do live in town or out in the country?
ratbag_359
Postby JamoAus » Thu Jul 07, 2011 10:24 am
Hi again,
It is a teaser. I live 16KM out of town, sort of semi rural. Neighbour has the same voltage @ 253 V.
Glenn
JamoAus
Postby ratbag_359 » Thu Jul 07, 2011 11:04 am
well the voltage is within limits.
But the motor should still run.
The only thing apart from the machine having a quirky fault is the supply for the house been bad like a bad neutral.
ratbag_359
Postby JamoAus » Sun Jul 10, 2011 6:17 am
Hi there,
Dropped the voltage to 249 by plugging in a 800 watt heater and machine worked perfectly. Have to ring my supplier to find out why it is high. Thanks for your help.
Glenn
JamoAus
Postby Allsorts » Sun Jul 10, 2011 7:16 am
Re the Voltage.. proberbly just means low demand on the supply
Allsorts - Where Recycling Means Being Natural
Supporting http://www.findmyrecycler.co.uk - connecting waste to recyclers
We are looking for more recyclers
Get a FREE listing on the database - Contact Us at Find My Recycler
Allsorts
Postby ratbag_359 » Sun Jul 10, 2011 9:17 am
There maybe a bad neutral on the transformer feeding your house.
Or the power in your area may need conditioning.
Allsorts wrote:Re the Voltage.. proberbly just means low demand on the supply
Agreed. Also bad neutral can cause it too. A few years ago in a rural area a lug for the neutral burned right off two houses ended up with 500volts coming in 8O
ratbag_359
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 30 minutes)
