by paulsimps » Sat Mar 22, 2008 5:26 am
My problem is the machine starts emptying 30 seconds after the wash begins. (Pump turns on). Then the water turns on to try and get the level back up.
Once I correct this fault(with power on/off etc) it will function perfectly for several more washes. After a day it goes back to emptying 10secs to 60secs into the wash cycle.
I checked the water level tube top and bottom- seems ok, no blockages.
After I stood the machine up again after laying it on its side to check underneath things got worse.!!!
It immediately started the 1 sec alarm beep as soon as I put the power plug in- I didnt even turn the power on at the machine!.
This always happens now- I cant clear this fault so cant do any washing.
The alarm code is 66 (0100 0010)
I rang F/P and all they would tell me was it was "an electronic" problem. !!
The digital board seems to be working as its toggling through all the key presses and diagnostic codes - so my feeling is its something external?
The water pressure sensor seems mechanically ok -the ferrite bead is moving up and down anyway with slight pressure to the sensor. But would that initiate an instant alarm on power up anyway.?
In diagnostic mode I can individually toggle the hot and cold solenoids. They both measure 60 ohms - so seem ok
Q1) What else is being monitored on power up??
Is there a list?
- elsewhere someone said the motor position sensor is monitored. ?
where is that? would that cause a power up alarm?
Q2)does it matter that the hot water inlet is not attached to anything? there is a slight trickle of water leaking backwards from it when filling - so the solenoid valve could be on its way out. Cause an alarm??
Q3) Out of shear curiosity. := At the top of the water pressure tube there is a fine piece of blue wire inside the tube about 200mms long. It is not connected to anything either end- it just sits there .
What does it do??? im very perplexed
Q4) I can toggle through 16 diagnostic words with the Spin Speed buttons.
I get 16 different light combinations
Other than the spin=HOLD+SLOW lights on do the other words have any meaning?
Q5) why would laying the machine down on its side affect anything?
Thanks in great anticipation
Paul (X Leeds)
paulsimps
by Penguin45 » Sat Mar 22, 2008 8:25 am
66 is the level switch giving readings which the computer board cannot interperate. As the switch is integral with the pcb, this is why you have been told that it's an electronic problem.
When you disconnect the air hose, the machine must be absolutely empty, otherwise there is water in the air chamber, which will throw the readings out even further.
(still in Leeds).
by paulsimps » Sat Mar 22, 2008 9:38 am
Hi Penguine
so is 66 definitely a water level problem??
the air tube is quite clean and dry - no water
But why would that create an immediate error on power on?
What now?
Paul
ps -and whats the piece of blue wire for inside the water level tube? (see Q3 above)
paulsimps
by kiwireeferman » Sun Mar 23, 2008 1:45 am
The blue plastic core is to stop the hose kinking and shutting off air flow.
kiwireeferman
- Regular Appliance Forum User
by kiwireeferman » Sun Mar 23, 2008 1:48 am
Smart Drive has a "power on, self test" and will alarm if any of the values are out of "normal range"
kiwireeferman
- Where to locate manufacture date on a MW511 top load washing
by eveandsuse » Sun Dec 12, 2010 2:36 am
- 6 Replies
- 1570 Views
- Last post by eveandsuse
Mon Dec 13, 2010 1:25 pm
- MW511: 00111000 Error Msg
by tommygunn01 » Thu Feb 14, 2008 8:40 am
- 1011 Views
Fri Feb 15, 2008 9:31 pm
- MW511 Error on power up (00110001)
by Planky » Sun Apr 22, 2007 5:37 am
- 7 Replies
- 3492 Views
- Last post by fabnz
Mon Apr 26, 2010 8:40 am
- F&P MW511 beeps without an error code
by camadio » Mon Mar 24, 2008 8:19 am
- 1070 Views
Mon Mar 24, 2008 11:49 pm
- mw511 error code 00101011
by kenjikool » Wed Mar 04, 2009 4:15 am
- 1209 Views
- Last post by kenjikool
Wed Mar 04, 2009 8:05 am
