by Gord » Sun May 22, 2005 11:54 pm
Hi there,
My little machine wont fill for the rinse cycle. It fills fine initially and can be filled with water manually (from a bucket!) but the tub just spins slowly (not filling) when the wash cycle is complete and drained.
Any help would be greatly appreciated.
Gord.
Gord
by Guest » Sun May 22, 2005 11:57 pm
Also, I have been into diagnostic mode and there is no light for the lid being open and also no light for the tub being out-of-balance. The water intakes and pump seem to work fine in this mode!!
thanks
GORD again.
by alexa » Mon May 23, 2005 12:46 am
Post your email or fax no. and I'll send you the diagnostics
alexa
by alexa » Mon May 23, 2005 1:09 am
I've emailed you the diagnostics
Post back to UKW with the fault code
If I'm not there then penguin 45 will assist when he's online
Do not email as I'm about to go on away and nobody will respond
Best if you could do this asap
alexa
by Gord » Mon May 23, 2005 3:41 am
Thanks so much
I'll have a look tonight
and post the relevant details tomorrow
- no rush
Thanks,
Gord
Gord
by Gord » Mon May 23, 2005 10:09 pm
The smartdrive is a phase 3 (MW053) compact 5kg+
Going into diagnostic mode does not produce 2 beeps!!
There is no fault code shown at Level 3!
Though:
Level 8 = 20
Level 9 = 37
Level 10 = 8
Level 14 = 42
Level 15 = 55
“Lid Open” LED goes on.
“Out of Balance” LED goes on
“Size Switch” goes on - 5.5kg
“Pump” goes on
“Hot water” LED goes on and opens hot water valve
“Cold water” LED goes on but valve doesn’t let water through properly.
even when i run a cycle on hot water, the machine wont fill at the rinse stage.
any assistance - greatly appreciated
GORD
Gord
by Penguin45 » Tue May 24, 2005 12:23 am
Have you checked the cold water solenoid coil Gord? Should give a reading of 3-4k ohms.
Power off first.........
by alexa » Sun May 29, 2005 9:31 am
Penguin 45 is right that the cold water solenoid is faulty
Their 12 volt supplied coils however should read 15 ohms and are basically bullet proof at these voltages
You should first check that the water runs freely through the hose and that the filter in the valve opening where you attach the inlet hose is free of debris/dirt
The valve itself is however a major source of income for repairers as their diaphram is of poor quality and will therefore split and subsequently won't let the water through properly.
Also these machines only rinse on cold water so a hot fill selection will not bypass this component.
Likewise the hot and cold valve are different and so cannot adequately be swapped
Drain the machine to avoid reboot errors
Ensure the power and water are off and disconnected at the wall.
Take all precautions not to get water in the electronics else forced air drying for a lengthy period will be required.
alexa
by SPLASHCYM » Thu Jun 02, 2005 9:25 am
I seem to be having a similar problem with my smartdrive 053. When filling the tub it 'sounds' wrong and a quick peek under the lid shows just a dribble of water making its way in...
If both of my inlet valves have packed it in, are they easy to replace? (without expensive repair labour bills of course)
SPLASHCYM
by alexa » Thu Jun 02, 2005 10:35 am
Yes they are easy to replace but then I,ve done it a 1000 times.
1/. Order the parts
2/. Wait till you have the parts before attempting replacement
3/. Turn power off
4/. Disassemble in an orderley fashion
5/. Reassemble in reverse.
Post here if you have any problems although I am going to the coast for the weekend so will be unavailable till Monday
Anyone should be able to supply or ph F&P 1300 650 590 24hrs for mailout of parts
Probably $100 max for both
Note there is a difference between hot and cold
Should take five to ten minutes Max.
You should allow 1 hr
alexa
- Smartdrive 051 , keeps on looping rinse cycle
by Cylon » Tue Mar 31, 2009 4:24 am
- 1197 Views
- Last post by Cylon
Sun Aug 02, 2009 4:10 am
- F&P SmartDrive GW603 Washing Machine Slow Water Fill
by Rot0r » Tue Nov 22, 2005 12:07 pm
- 1763 Views
- Last post by KiwiwantsworkinCanada
Thu Nov 24, 2005 6:27 am
- F&P Inutuitive Washing Machine wont fill to High
by twp66 » Sun Jan 02, 2011 12:52 am
- 626 Views
- Last post by twp66
- F&P Smartdrive 703 rinse fault
by pablot » Wed Jun 07, 2006 2:29 pm
- 1242 Views
- Last post by pablot
Sat Jun 10, 2006 8:05 am
- Smartdrive GW500B-K not getting past first rinse
by DaveP68 » Wed Jan 16, 2008 10:58 pm
- 1232 Views
- Last post by DaveP68
Wed Feb 13, 2008 11:36 am
