by Ozzy1 » Wed Sep 30, 2009 3:59 am
Hello All
Have a Westinghouse GOL476WNG Wall Oven around 3 years old.
Had to replace the Glow Bar and Burner as the last 4 or 5 burner holes had collapsed and created a largish hole in the far end of it where Glow Bar sits. (It appeared to be heat damaged)
After replacing Glow Bar and burner, I noticed that the Flame seemed quite large (around 4-5 inches at Glow Bar end and 3-4 inches at inlet end).
I am concerned that this may have led to the burner and Glow Bar failing and dont want a reapeat of this. The flame is Blue in colour with occasional Orange Tips at the Glow Bar end.
Could a Gas pressure or other adjustment be required to reduce the flame size or is this normal for this model of oven ?
Ozzy1
- Appliance Forum User
by Ozzy1 » Fri Oct 02, 2009 8:25 am
Any comment would be most welcome
Ozzy1
by Ozzy1 » Thu Oct 15, 2009 7:20 am
Surely somebody has an idea of how high the flame should be ?
Anyone ....................?
Ozzy1
by Penguin45 » Thu Oct 15, 2009 7:18 pm
Sorry, Ozzy1 - I'm not a gas engineer, so can't advise you. It's a bit pot luck which Oz engineers pop in, so I can only suggest patience.
- Westinghouse BJ423T
by Cylon » Wed Mar 23, 2011 11:02 pm
- 531 Views
- Last post by Cylon
- Westinghouse Silhouette fridge/freezer
by Aussiev8 » Fri Mar 16, 2007 9:56 pm
- 1011 Views
- Last post by Aussiev8
Fri Mar 16, 2007 10:05 pm
- Westinghouse LT 609 Setup/programming guide
by Cylon » Wed Mar 28, 2012 5:51 am
- 261 Views
- Westinghouse BJ414 Fridge/Freezer has timer?
by ThirdMonkey » Sun Dec 10, 2006 2:10 am
- 1388 Views
- Last post by ThirdMonkey
Sun Dec 10, 2006 12:07 pm
- Westinghouse RJ422E Silhouette earth leakage on defrost
by lisaellamaurice » Sun Feb 26, 2006 9:52 pm
- 919 Views
Sun Feb 26, 2006 11:38 pm
Users browsing this forum: No registered users and 5 guests
