Bosch Gas Hob Ignitor Not Working
 Oven & cooker fan motors
Should you need a new fan motor for your built in oven, cooker or range cooker that are a common cause of noise or uneven cooking then we can supply almost any for UK ovens and cookers often at low prices and with many compatible fan motors stocked. Find replacement fan motors in our store for all major brands including Britannia, Bosch, Beko, Lamona, Rangemaster, Smeg and many more
Buy oven fan motors for built in ovens and cookers online
by pmac » Fri Feb 24, 2012 9:20 pm
Hi all, I have a Bosch 5 burner gas hob, and the ignitors have stopped working on all of the burners. It is the type where you push down the regulator to operate the ignitors, but when you push it down you get no clicking or any sign of life. I have checked that all of the electrodes are clean and clear, and that that the 230v supply is live and getting to the hob. You can light the burners with a lighter, and they remain alight, so I assume the thermocouplers are working correctly. Is there a central spark generator in the hob that I can replace, or any other common fault that it could be?
The only numbers I can find on the hob are on the plate on the underside of the hob, they are as follows:
E-Nr PCL785FGB /07
FD 8602/00255
Type HSE-7FB4W30 CE-99BM748
If there are any parts I can replace, any pointers of what parts I need, or any help at all, will be greatly appreciated.
Many Thanks in Advance Paul.
pmac
 Oven & cooker door hinges
by r600a » Sat Feb 25, 2012 2:32 am
Looks like the ignition generator has failed.
Bryan
r600a
WTA Team Member
WTA Team Member
by pmac » Sat Feb 25, 2012 7:59 am
Thanks Bryan, any ideas where I can get one from, are they unique to that model or do Bosch do a generic one?
I have searched for one on the Ukwhitegoods site, but have had no luck finding one. Can it be repaired, or is it time for a new hob?
Thanks Again Paul.
pmac
by Martin » Sat Feb 25, 2012 8:39 am
pmac wrote:but have had no luck finding one.
Try clicking HERE :wink:
by pmac » Sat Feb 25, 2012 7:30 pm
Thanks for the help and advice guys, I have ordered one, it will be with me next week, ready for a mate of mine who works for gas board to fit.
This is a fantastic forum, that has got me out of trouble several times, I would like to thank you all, and keep up the good work.
Paul (pmac)
pmac
by mossy1283 » Sun Sep 16, 2012 9:25 am
Just out of interest did this ignition transformer work? I have got the same problem with my hob too which is the same model.
mossy1283
