Bosch WAE 24363GB error code F:21
by Taffy63 » Sat Mar 27, 2010 4:39 pm
Hello, I have a Bosch Classixx 6 1200 washing machine. Firstly the machine did not spindry a wash completely. I tried to run the spin cycle again but an error code F:21 appears on the LCD.
I checked the carbon brushes, and these were very worn (only about 5mm left). So I have changed the brushes, but the error code still appears. None of the buttons on the display panel appear to work, but the wash selector button turns the machine on/off.
Does anyone know what this error code means or how to re-set to test new brushes?
Thanks for your patience.
Taffy63
 Washing machine drain pumps & parts
If your washing machine will not drain the cause will normally be that either your drain pump is blocked or faulty resulting in the machine failing to empty. You can buy replacement drain pump including many low cost compatible washing machine pumps in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
Drain pumps for most washing machines including popular makes like AEG, Hotpoint, Beko, Baumatic, Bosch and many more
by gegsy » Sat Mar 27, 2010 8:51 pm
It would appear that you have a faulty module and quite possibly a damaged motor. :(
Greg
gegsy
by neilbow » Sat May 29, 2010 2:27 pm
Greg I think you are wrong about the module I have just had the same fault on a bosch classixx6 1200 WAE24363GB, and it appears once the error code comes up you have to reset the module. there are two ways 1)Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button 2)turn it to spin (the six o'clock position), then hold down the RPM/Spin button and turned the dial one click clockwise and then let go of the RPM/Spin button. (the rinse hold light lit up and it beeped) I then switched to off and then back on. and it is currently on test and working fine Regards Neil :-)
neilbow
Valued Contributor
Valued Contributor
by nomadPaul » Sat May 29, 2010 3:07 pm
If it then re-occurs , check out the brushes in the motor because thats what F:21 is related too.
nomadPaul
by neilbow » Sat May 29, 2010 3:21 pm
The brushes were low which is what I think kicked off the F21 Error. Brushes changed, machine on test, all seems well. :-)
Regards Neil
neilbow
Valued Contributor
Valued Contributor
 Washing machine drum paddles
Broken drum paddles or lifters are often a fairly easy part to replace yourself and you can buy replacement drum paddles including many low cost compatible washing machine paddles in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
“Drum
