by 332l2 » Fri Aug 21, 2009 4:32 pm
Hi Guys my first post here, and hopefully you can help.
I have just replaced the element of the fan oven of the above model oven.
Oven 3 years old.
I now have the following problems.
When switching on the power I get the following codes.
068 followed by 19 1, from a previous posting I believe this is the software number, but could someone confirm as I dont remember seeing it before.
When I switch on the oven and set a temperature it heats up and reaches its target temp and beeps at me. It does not stop heating up so I have to switch it off.
If I dont the clock display dissapears.
If I dont let it cool down it also will continue to heat up even after I have switched power off and the oven is off when I re apply power.
It does this with both the fan oven and the main oven.
Help please.
John
332l2
by Penguin45 » Fri Aug 21, 2009 7:51 pm
Power board on top of the fan ducting is almost certainly damaged.
- AEG Competence D5701-4 Main Oven Failure
by DaveR » Fri May 25, 2007 7:38 pm
- 7 Replies
- 2364 Views
- Last post by DaveR
Thu May 31, 2007 7:38 am
- AEG Competence d5701-4 Error Codes - Bottom oven problem.
by Redwine » Thu Feb 28, 2013 10:57 pm
- 10 Replies
- 436 Views
- Last post by Martin
Sat Mar 02, 2013 8:15 am
- AEG D5701-4 Thermostat Problem
by CamR » Sun Jan 08, 2012 11:06 am
- 318 Views
- Last post by CamR
- AEG Competence 305 B-W
by Smythy » Mon Mar 12, 2007 9:49 pm
- 770 Views
- Last post by Dave_Conway
Mon Mar 12, 2007 10:37 pm
- aeg competence B2190-1
by mash » Sat Apr 01, 2006 10:48 pm
- 873 Views
Sun Apr 02, 2006 12:18 am
Users browsing this forum: No registered users and 24 guests
