Bosch HBN3550GB doesn't heat and no fan
Postby dave j » Sun Jul 09, 2006 5:37 pm
Neither the oven element nor the grill heat up and the oven fan doesn't come on either. It stopped suddenly rather than being intermittent. The light inside the oven works as do the timer and lights above the control knobs.
Anything I should be focussing on? I'm assuming it will be something like a blown fuse or faulty switch mechanism.
Thanks.
dave j
dave j
Re: Bosch HBN3550GB doesn't heat and no fan
Postby gegsy » Sun Jul 09, 2006 5:54 pm
Is the clock set to manual (hand symbol) rather than auto?
Greg
gegsy
Postby dave j » Sun Jul 09, 2006 8:12 pm
I guess that's the "make sure they've not got the timer on" question. :)
There is no hand symbol on the display or mentioned in the manual.
I have gone through the "turn off the timer" procedure, set the time/duration to 00:00, but that made no difference.
dave j
dave j
Postby gegsy » Sun Jul 09, 2006 9:32 pm
dave j wrote:I guess that's the "make sure they've not got the timer on" question. :)
How did you guess :D but you would be suprised how many calls we goto that have the clock set to "auto" or not set at all. You have set the clock havent you, I know you mentioned duration 00.00.
If all that is done I would suggest an engineer from the link below.
Greg
gegsy
Postby dave j » Sun Jul 09, 2006 10:15 pm
I've done IT support in the past and know how frequently things like that can come up. Not plugging things in at the wall was always a good one. :)
Yes. The clock's set. I even got it to run through a start/stop cycle on the timer and that all worked - apart from the heating up bit. :(
Greg
OK Thanks for the help.
dave j
dave j
Postby Martin » Mon Jul 10, 2006 7:47 am
dave j wrote:The light inside the oven works as do the timer and lights above the control knobs.
Here's a clue (above) to the fault :wink:
The 'Temperature Limiter' has shut off (thermal fuse) for some reason?
Check link below for a local engineer to look into it for you :wink:
Users browsing this forum: No registered users and 18 guests
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 30 minutes)
