Double oven - main oven cutting out - top oven ok
Postby Luigi » Thu Nov 29, 2007 4:06 pm
I have an Electrolux EOD984W approx. 9 years old.
Main oven cuts out completely (no heat/fan/light) after 30 - 40 minutes or so. Will re-start when cooled down somewhat.
Top oven will still work though and fan for controls is working fine.
Is there a separate thermal cut-out for each oven - if so then is this the likely cause?
Or could it be be the main oven thermostat or something else entirely??
Advice gratefully received.
Luigi
Re: Double oven - main oven cutting out - top oven ok
Postby Penguin45 » Sun Dec 02, 2007 12:51 pm
There is a safety thermostat for the main oven mounted on the back - usually a white ceramic block with a coulple of wires. Given the passage of time before it trips, it may well actually be doing its job - you need to check whether or not the oven thermostat is cycling.
3115190-05/4 - safety cut-out
3111622-01/9 - main oven thermostat
spares@ukwhitegoods.co.uk will be able to supply any parts required.
Power off if investigating.
Postby Luigi » Mon Dec 03, 2007 12:05 pm
Thanks for the advice. I replaced the saftety cut-out and all seems ok. Main oven run at 220c for an hour and all is fine.
Will borrow an oven thermometer to check main thermostat but I think it's ok.
Luigi
Users browsing this forum: Google Adsense [Bot] and 14 guests
In total there are 15 users online :: 1 registered, 0 hidden and 14 guests (based on users active over the past 30 minutes)
