Hot plate thermostat problem?
Postby bigbunions » Sat Nov 19, 2011 8:42 am
Hi, I have a stoves 61EHDO and am experiencing a problem with the temperature control.
It would seem obvious that thermostat has gone, however the problem is intermittent and I thought once the thermostat had gone it was gone totally?
We've found that if we turn the plate on by turning the control knob anti-clockwise to full heat, give it a blast of heat then turn it down to where we want it, it then controls the temp normally. If we turn it on from cold turning the dial clockwise, the plate never turns off, burns food and ruins pans. Only last week my halogen plate stared doing this as well (back right has been doing it for some months). It looks like the element, and thermostat are all part of one unit and as the halogen one alone is around £130, I'd like to be sure it is this that is at issue.
Is it possible there's something else at fault, for instance the control knob or is there some other cut-off between the switch and the plate?
Any advice would be greatly appreciated.
bigbunions
Re: Hot plate thermostat problem?
Postby Simon46 » Sat Nov 19, 2011 9:05 am
Sounds like there is a fault with the regulator under knob. The only other component is the limiter rod in the halogen unit. this switches on hob hot light and stops from overheating.
Power off if youre going in.
Simon
Simon46
Postby bigbunions » Sat Mar 17, 2012 2:18 pm
Thanks Simon, taken me this long and a couple of blackened pans later to finally replacing the regulator as you suggested.
Got the new one in and is like brand new. Many thanks for your time.
bigbunions
Users browsing this forum: No registered users and 25 guests
In total there are 25 users online :: 0 registered, 0 hidden and 25 guests (based on users active over the past 30 minutes)
