SMEG Oven - SE 375 MSX - Problems
Postby Hazel » Mon Jun 20, 2005 2:33 pm
Hello Anyone,
Above oven is approximately 5 ish years old - and was in the house we moved into a few years ago.
Several things are worrying me: -
1. Don't know if this is normal but the door seems dangerously hot when the oven is on. Don't have kids, otherwise this would be a major problem.
2. It seems to smoke (as in grease/food rather than electrical) every time I use the oven. It's so bad that I have to have all windows open (kitchen is quite small) and can't use it if we have guests. I had it professionally cleaned about 6 months ago and it was fine for about 2 months. It's bad enough with the fan-assisted selector control, but if I ever just use the "regular" control, it's just awful.
It's kept pretty clean and I just don't know what the problem is.
Help!
Any suggestions?
Hazel
Hazel
Re: SMEG Oven - SE 375 MSX - Problems
Postby Simon46 » Mon Jun 20, 2005 3:10 pm
Does it appear hotter than usual/burning food/taking longer for the light to go out when it has reached temperature?
Simon
Simon46
Postby Hazel » Mon Jun 20, 2005 3:42 pm
Hi Simon,
I think it's always been this hot (and has been the bane of my life since moving in here).
Yes, it does tend to burn things - especially cakes - they go black around the edges before the inside is cooked. I do reduce the recommended cooking temperature when using fan-assisted. I have started having to cook some things covered in foil just to avoid the smoking and burning smell.
It takes about 20-25 minutes to heat the oven up to 180 dg C. I'm not sure how quickly it's supposed to heat up but that is another annoyance. :?
Would welcome your comments/suggestions.
Thanks, Hazel
Hazel
Postby Simon46 » Mon Jun 20, 2005 3:55 pm
Hazel
If you know anybody with an oven thermometer to check temp selected against actual temp. If the fan in the oven is spinning o.k. i suspect the oven to have a temperature control fault. Idont know if there is one in your area but John Lewis sell them. Otherwise cliking on Repairs@ on LHS of screen may be able to help you regarding fixing it.
Simon
Simon46
Postby Hazel » Mon Jun 20, 2005 4:05 pm
Thanks for that Simon,
I'll try and get hold of an oven thermometer. Am in London so plenty of John Lewis stores around.
Re: the fan - it sounds like it's spinning - as in, a totally different sound compared to just using the convection oven setting.
Do you know if a temperature control fault is serious (expensive) to fix - if that is the problem?
Thanks again for your replies.
Hazel
Hazel
Postby Simon46 » Mon Jun 20, 2005 4:12 pm
Not that expensive but cheaper than new oven! I had a lady who was so pleased with her repair she kindly donated some hot pasties to me. :D
Simon
Simon46
Postby Hazel » Mon Jun 20, 2005 4:36 pm
Donating hot pasties sounds like one satisfied customer Simon!! Bet she wouldn't have made them for you on a day like today though 8).
I have no idea how much new ovens are - would a repair like this be £100 or £100's. Sorry to ask - I know you can't be specific but a rough idea.
Will try the thermometer thing and take it from there. What you have said makes sense though. Is 20-25 mins to heat up 180 deg C longer than it should take?
H
Hazel
Postby Simon46 » Mon Jun 20, 2005 4:48 pm
All depends on labour charge in London. I would do it but in Cheshire. Try thermometer first and get back to us. smoke usually means over heating unless there is a lot of fat from grilling.
S.
Simon46
Postby Hazel » Mon Jun 20, 2005 4:50 pm
Thanks, will do. :D
Hazel
Users browsing this forum: Google [Bot] and 23 guests
In total there are 24 users online :: 1 registered, 0 hidden and 23 guests (based on users active over the past 30 minutes)
