STOVES 720GR bottom oven not working
Postby tanky1 » Sat Mar 10, 2007 9:40 pm
Needed advice on an issue with my stoves 720gr bottom oven. When I try to switch the oven on, the fan rotates and I can see the ignition spark, but fails to fire up. After sveral attempts I can see a green flashing indicator light in the display panel.
Looked at the usuer manual which seemed to suggest that it could be in safe mode. Have switch the appliance off and on and still have the same problem. The top oven and grill seem to be working fine
Any suggestions? Do I need an engineer or is it something simple I could resolve?
Many thanks.
tanky1
Re: STOVES 720GR bottom oven not working
Postby Penguin45 » Sun Mar 11, 2007 1:34 am
Any non-igniting gas oven needs professional service only. Please - find your local CORGI engineer.
Postby tanky1 » Sun Mar 11, 2007 9:52 am
Ok Penguin45, will do!
tanky1
Postby wsts » Mon Mar 12, 2007 12:18 am
Your local gas engineer will be as much use as phoning a landscape gardener on these ovens unless your local engineer is an ex stoves engineer, also this repair could be very expensive.... be warned.
wsts
Postby tanky1 » Mon Mar 12, 2007 9:01 pm
8O Oh no! Thanks for the heads up wsts. Any suggestions on how to locate an ex stoves engineer in my area :?:
tanky1
Postby wsts » Thu Mar 15, 2007 12:29 am
Depends what area you are in.
wsts
Postby tanky1 » Fri Mar 16, 2007 11:42 am
wsts wrote:Depends what area you are in.
North West London...Harrow.
tanky1
Postby jerry49 » Mon Aug 27, 2007 10:54 am
Tanky1 I,ve got a 720gra with a problem, I thought I,d ask you simply because you have a very similar model. My oven/grill knob is very very resistant to being turned to the right to ignite the grill. It turns to the left to light the top oven. Can you relate to this and any clues how the panel with the knobs on comes away after removing the knobs?
jerry49
Postby tanky1 » Tue Aug 28, 2007 10:05 am
Sorry, not a problem I've had. My problem was a faulty gas valve, which was fixed by stoves.
tanky1
Postby jerry49 » Tue Aug 28, 2007 5:11 pm
When it was being repaired can I assume they didn,t remove the panel with the knobs on, if only to know that it can be removed.
jerry49
Postby tanky1 » Tue Aug 28, 2007 8:14 pm
They didn't remove the panel.
tanky1
Users browsing this forum: Robin_Hood and 22 guests
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 30 minutes)
