Zanussi oven thermostat wiring
Postby aarkadian » Tue Apr 17, 2012 3:39 pm
My oven stays at maximum temperature regardless of the setting of the temperature control so I decided to replace the thermostat. According to all the parts suppliers I tried, the original thermostat is obsolete.
Oven Brand: Zanussi
Oven Model: ZHQ575W
Oven Product Number: 944171206
Obsolete Thermostat: 47THC23/F5 (or 3111622019)
I found Ransom Spares before I found this site and they said that Zanussi recommend this one instead so I bought it:
New Thermostat: http://www.ransomspares.co.uk/parts/cookers-hobs/zanussi/thermostat/85474.htm?m=23645
But it has fewer connectors than the original. I have checked again with the suppliers and it is right. I think I may need to connect multiple wires to one or more of the connectors but the unit comes without diagrams, and neither Ransom Spares nor Zanussi can help.
Can anyone help me work out which wires go where?
aarkadian
Re: Zanussi oven thermostat wiring
Postby kwatt » Tue Apr 17, 2012 3:51 pm
I could be wrong but, I don't see how you could fit that thermostat as the original has a switch assay built into the front of it. That stat doesn't have the ability to do that unless there's some modification to allow it to fit.
We do list it as obsolete with no alternative available that I am aware of.
Postby aarkadian » Tue Apr 17, 2012 4:10 pm
Hi kwatt
Thanks for looking.
The appliance has two knobs to control the main oven. The first knob is the temperature control which has just the thermostat behind it. The second knob is the function selector which has the switch assembly behind it. The two are connected by several wires.
aarkadian
Postby Washman » Tue Apr 17, 2012 6:14 pm
There are 2 versions of that oven ,the stat that you have been sent is for the other version and is not interchangeable with your oven.
Washman
For safety remove plug from socket before removing any panels or attempting any repair to your appliance.
Washman
Postby aarkadian » Tue Apr 17, 2012 9:04 pm
Hi Washman
Thanks for your response. The spare parts search on this site lists my part number (3111622019) as obsolete and then explains that this means
...there is no availability of that part and there is no alternative listed.
So unless someone has any other idea, it looks like this is the end of the road for my oven.
aarkadian
Postby Applianceman2010 » Tue Apr 17, 2012 9:54 pm
I think it is this stat: connect number (sorry don't have a part number maybe someone could help out?) 5031680008760 that you need (its gunna take a bit of re wiring the instructions that come with it are utter garbage NOT an easy job!)
Domestic Appliance Repairs , Does as it says on the tin! http://www.ukwhitegoods.co.uk/search/fi ... ineer.html
Applianceman2010
Postby bazza500 » Tue Apr 17, 2012 10:09 pm
Applianceman2010 wrote: 5031680008760
number converts to 3110939000
bazza500
WTA Team Member
WTA Team Member
Postby Applianceman2010 » Tue Apr 17, 2012 10:13 pm
thanks bazza!
Applianceman2010
Postby Applianceman2010 » Tue Apr 17, 2012 10:46 pm
On espares i think its
Stock Number: ES875714
Manufactured by Zanussi
Part No. 506008303006
but its not n easy job BE WARNED! lol
Applianceman2010
Postby aarkadian » Mon Apr 23, 2012 10:00 am
@bazza500 and @Applianceman2010: Thank you for the advice but I think fitting that part, with the necessary rewiring is too much for my skills. But do read on for something interesting which might make the repair much easier.
On the connect-plus site, for the main oven they show a thermostat which appears to have seven connectors, just like mine has. For the top oven they show one with just two connectors plus earth. The interesting thing is that on each of these two web pages there is a note to say that the product is wrong and that if you want the main oven thermostat you should buy the one they sell for the top oven, and vice versa.
It looks like they are already selling the right thermostat for each oven. The note which is supposed to correct an error should be removed. This misinformation seems to me to be the reason that all the parts suppliers are selling a main oven thermostat with too few connectors. Connect-plus got the misinformation and added errata to their database and web pages, which makes it easy for us to suspect misinformation. Other suppliers on the other hand have updated their systems so that they are now showing the wrong thermostat for each of the ovens. Anyone buying just one will get the wrong part and have a hard time wiring it in.
So the thermostat that I believe I need for the main oven is 47THC9/F8 aka ET52001-F8 aka DST506008433001. I have ordered one and will let you know how I get on.
aarkadian
Postby aarkadian » Tue May 01, 2012 8:51 pm
I'm happy to report that everything went well and the oven is working fine now. In summary if you want a main oven thermostat for a ZHQ575 check very carefully what your parts supplier is going to sell you. I successfully replaced mine with a 47THC9/F8 aka ET52001-F8 aka DST506008433001.
Wiring up the new thermostat was easy as it looks a lot like the old one and has the same number of connectors and similar layout and labelling. I wired the new connectors 1, 2, 3, 4 and 6 as they were previously. I left 5 unused, as before. The new thermostat has connectors A, B and C where the old one had F, G and H. I wired A and B as though they were the old F and G respectively, and left C unused, just as H was. I got the A=F and B=G part from the post below:
http://www.diynot.com/forums/viewtopic.php?t=160349
The whole experience was long and frustrating and I nearly gave up thinking it might be wiser to buy a new oven. I'm glad I didn't as it would have been a waste of a perfectly good £500 oven which in the end I fixed for £40. :D
Thanks for everyone's input along that way. I hope this tale helps someone else.
aarkadian
Users browsing this forum: No registered users and 10 guests
In total there are 10 users online :: 0 registered, 0 hidden and 10 guests (based on users active over the past 30 minutes)
