Zanussi ZCE7610w
Zanussi ZCE7610w
Postby gingermandan » Tue Aug 03, 2010 1:48 pm
I have the above cooker and it has stopped working.
i turned on the right front hob and it fused the main fuse board with a small puff of smoke. now when i switch the plug on it fuses the main board each time.
also the main oven (fan) just cuts out after about 2 minutes and the light flickers.
Please Help
gingermandan
Re: Zanussi ZCE7610w
Postby Steven » Tue Aug 03, 2010 9:59 pm
Ring regulator switch probably faulty. Usually comes with new wiring as well.
May need product code to double check part number should be. 3116724000
Does the fan oven still heat when the fan stops, or does the whole oven shut down?
Unless you are confident about undertaking this repair; suggest you get in touch with your local repairer.
contact repairs@
Dont forget to isolate mains supply :!:
Steven
WTA Team Member
WTA Team Member
Postby gingermandan » Thu Aug 05, 2010 9:26 am
The fan starts to heat up and then the light the fan and the heat just die.
Thanks for your reply though
gingermandan
Users browsing this forum: No registered users and 8 guests
In total there are 8 users online :: 0 registered, 0 hidden and 8 guests (based on users active over the past 30 minutes)
