by Colossus » Mon Aug 08, 2005 11:02 am
We have an AEG F60870M dishwasher which is leaving food debris and marks over some of the crockery, mainly in the top drawer, although the bottom is also affected. Appears to be slightly intermittent but seems to be getting worse. It looks like it is washing properly but then not getting rid of the food debris when rinsing. It then gets baked on when the washer goes into the drying cycle. Anyone have any idea as towhy this might be happening? Have looked at the spray arms and these appear clean and clear of blockages. Many thanks.
Colossus
by Dave_Conway » Mon Aug 08, 2005 12:03 pm
It sounds like an upper spray arm problem to be honest.
Set the arm to a certain angle then start the dishwasher up, let it start to wash then switch off and open the door to see if it's moved. It may be that the arm and/or support are worn and it isn't rotating.
by Colossus » Mon Aug 08, 2005 12:22 pm
Dave
Thanks for your advice. The machine is only 5 months old and hopefully shouldn't be worn and before I go to the hassle of getting someone to look at it under warranty (assuming they find a problem) I thought I would ask for advice. I will check for arm rotation this evening and see how we go. Many thanks for your input.
Carl
Colossus
by CJ » Mon Aug 08, 2005 5:05 pm
More likely to be either a filter (visible under the bottom basket) not fitted correctly and therefore bobbing up and down when washing or possibly the detergent chosen.
I would try using a good quality standard detergent rather than one of these new combined 3in1 or 4in1 types, especially if using a seperate rinse-aid too.
Check the filters first, if the holes in the rotating spray arms are blocked it is a sign that the filters were not in place. If this is the case it may take a couple of washes to clean itself out again.
cj
CJ
- Regular Appliance Forum User
by Colossus » Tue Aug 09, 2005 8:08 am
CJ
Thanks for your response, which is helpful. I have checked the filters and all were in place but did also check the arm rotation as suggested by DAve and it wasn't turning as it should. I think there is an issue with it not connecting properly to the back of the machine where the water feed is, the seal does not appear to be particularly tight but with a good shove it seemed to connect enough to start moving the arm. I will see how we get on with this but your comments on the 3in1 powders are interesting. Is your view that they are not as effective as general powder and rinse aid> Cheers. Carl
Colossus
- bosch dishwasher not rinsing properly
by oofus18 » Tue Jul 27, 2004 10:32 pm
- 11 Replies
- 4608 Views
- Last post by Dave_Conway
Thu May 12, 2005 9:23 pm
- Help Please - De Dietrich VZ9996U1 Not Rinsing Properly
by BobBoulby » Tue Aug 08, 2006 7:40 pm
- 12 Replies
- 2123 Views
- Last post by BobBoulby
Wed Aug 09, 2006 10:30 am
- zanussi dw 927 not rinsing
by Glg » Fri Nov 07, 2008 3:17 pm
- 745 Views
- Last post by Glg
Sun Nov 09, 2008 1:47 pm
- DCS 14W Zanussi Rinsing Problem
by LadyQuake » Sat Jul 08, 2006 7:47 pm
- 9 Replies
- 1527 Views
- Last post by LadyQuake
Sun Jul 23, 2006 10:30 pm
- Brandt integrated vy450 not rinsing
by dlmn14 » Sat Oct 27, 2007 11:16 am
- 694 Views
- Last post by dlmn14
Users browsing this forum: No registered users and 17 guests
