by leithant » Mon Oct 03, 2005 8:14 am
Hi there,
I have an AEG OKO FAVORIT 5040, which was not filling nearly enough. I have discovered you can adjust the level via two screws on the pressure switch on the left hand side. It now fills perfectly in the wash cycle, but on rinse it fills ok then when the wash pump engages, the second fill goes slightly two high, causing eventual overflow. Which screw controls which level? Is the switch faulty? etc
many thanks
leith
leithant
by clivejameson » Mon Oct 03, 2005 8:18 am
Hi leith
The screws on the pressure switch both correspond to one level setting, one determines the pressure level at which the switch will close inside and the other determines hte pressure drop before the switch will re-open.
These are set during production and are not intended to be adjusted so if there is a problem with the operating level then replacement is the only real (and safe) alternative.
Have a look in Repairs@ for an engineer to help.
clivejameson
- Appliance Forum Veteran
by Martin » Mon Oct 03, 2005 8:21 am
Once you adjust those screws on a pressure switch you immediately trash it! You will need a new pressure switch and clear the blockage in the water level air bottle that is causing the problem!
- Appliance Guru
by leithant » Mon Oct 03, 2005 9:42 am
Oh Dear!
I thought they would have sealed them off it that was the case.
"The screws on the pressure switch both correspond to one level setting, one determines the pressure level at which the switch will close inside and the other determines hte pressure drop before the switch will re-open."
Do you know which is which? It seems like the outside one is the initial setting. Why does it trash trhe unit BTW?
"Once you adjust those screws on a pressure switch you immediately trash it! You will need a new pressure switch and clear the blockage in the water level air bottle that is causing the problem!"
What do you mean by the air bottle? The flat plastic one on the left side? Their didn't appear to be any visible blockage.
Thanks for your very speedy replies guys!
leithant
- indesit D63 fill level problems and non dissolving tablets
by mbge5amw » Sat Mar 25, 2006 8:46 pm
- 1054 Views
Sun Mar 26, 2006 12:07 am
- candy water level system?
by leejohn » Wed May 25, 2005 8:49 pm
- 650 Views
Wed May 25, 2005 11:04 pm
- Electrolux ESL 4114 Water level?
by kingpenda » Wed Mar 01, 2006 1:07 pm
- 611 Views
- Last post by kingpenda
- smeg DWI 710E1 level control
by diy » Thu Feb 15, 2007 9:34 pm
- 511 Views
- Last post by diy
- Miele G665SC Low water level
by woosing » Thu Sep 18, 2008 7:41 pm
- 874 Views
- Last post by willdawson
Fri Jan 06, 2012 4:23 am
Users browsing this forum: Google Adsense [Bot] and 11 guests
