BF1620 DISWASHER
BF1620 DISWASHER
Postby victory » Fri May 08, 2009 4:39 am
The dishwasher does not heat up during its cycle even though there is current going to the heater while its on.
I have purt an independent cable on the heater and plugged it into the mains and it works, can does anyone know what the problem might be please.
victory
Re: BF1620 DISWASHER
Postby clivejameson » Fri May 08, 2009 5:52 am
How have you established that there is current going to the heater?
Clive
Sharley Domestics Repair and Sales
Light travels faster than the speed of sound...which is why some people appear bright until they open their mouth.
clivejameson
Postby victory » Fri May 08, 2009 5:58 am
yes i have
victory
Postby clivejameson » Fri May 08, 2009 6:01 am
The question was HOW?
Clive
clivejameson
Postby victory » Fri May 08, 2009 6:06 am
i put my current tracer on it and it lit up.
victory
Postby clivejameson » Fri May 08, 2009 6:12 am
I take that to be the infamous neon screwdriver or something similar? These are highly dangerous and in any case will only show the presence of voltage...nothing to do with current.
We can never condone live testing by the public let alone rigging separate supplies to components!
Having said that, if you found the element heated when it was given a supply then it can only be a heater supply fault...being an Indesit in disguise it could be a whole number of things from the pcb down.
Power disconnected at ALL times when working on it please :zap:
Clive
clivejameson
Postby victory » Fri May 08, 2009 7:24 pm
apart from the pcb what else could it be, i am trying to determine if its worth fixing
victory
Postby clivejameson » Fri May 08, 2009 8:26 pm
The only way to find out is with a miltimeter to chase the wiring back from the heater onto the relevant track on the pcb...that will check everything except the pcb itself so if you have a good circuit to and from the heater then that just leaves the pcb itself.
Knowing these machines, if i was a gambling man my money would be on the pcb i'm afraid :?
Clive
clivejameson
Postby victory » Fri May 08, 2009 10:10 pm
thank you, the pcb is about £30
victory
Postby iadom » Fri May 08, 2009 10:16 pm
Take care, there are two different PCB's dependent upon serial number. :wink:
One is around £30, they other is almost twice as much. :cry:
Jim.
Postby Penguin45 » Fri May 08, 2009 11:48 pm
iadom wrote:Take care, there are two different PCB's dependent upon serial number. :wink:
Jim.
Although they look identical..........
Postby victory » Sat May 09, 2009 8:30 am
thanking you for your assitance
victory
Users browsing this forum: Google Adsense [Bot], storky and 28 guests
In total there are 30 users online :: 2 registered, 0 hidden and 28 guests (based on users active over the past 30 minutes)
