Bosch dishwasher - no heat
Postby Guest » Fri Oct 08, 2004 8:39 pm
Hi Hope you can help..
We have a bosch dishwasher sgs6312gb/13 that has stopped "heating up" it seems to run through the process and we have tried different programmes but it is still cold.
The machine is approx 4 yrs old and is not used heavily,no previous problems.
Any thoughts anyone - i am electrically "competent" but am not an appliance person.
Chris
Re: Bosch dishwasher - no heat
Postby sparkey » Fri Oct 08, 2004 10:33 pm
Guest,
Most likely cause is failure of printed circuit board at heater relay connection, con sometimes be resoldered if not new board required.
if you are unsure best to contact experienced engineer either post your post code or use 'directory' to the left of forum column.
As we always say PULL OUT THE PLUG
regards
Sparkey
sparkey
Postby Guest » Sat Oct 09, 2004 7:43 am
Thanks for the view.
We will probably get someone in. You never know sometimes it's a "thats well known and is caused by a £2 switch failing" answer. In which case i would be happy to swap the offending part.
I work for an "electricity board" (as was!) and miss not having "our" appliance guys to ask these questions of (times change and we only do our core work now), the site seems to be an excellent resource - one for my favourites.
Postby guest » Mon Dec 20, 2004 8:15 pm
Hi mine has done the same thing, it is the same model and age. How did you get it fixed and what was the problem ?
Thanks Andrew
guest
Users browsing this forum: johnmac11, RepairAid and 44 guests
In total there are 46 users online :: 2 registered, 0 hidden and 44 guests (based on users active over the past 30 minutes)
