Bosch Dishwasher not draining
Re: Bosch Dishwasher not draining
Postby Karen » Thu May 12, 2005 1:17 pm
Thinking of buying a Bosch champion sgs55E12 - is it better than the sgs45202?? I have had a bosch for 15 years which has done well but leaking.
How long is the normal programme?
Karen
Karen
Postby Martin » Thu May 12, 2005 1:57 pm
Karen wrote:How long is the normal programme?
About 2 hours!
Postby Guest » Fri Jun 03, 2005 7:51 pm
hi,
folks I have the same problem mine is BOSCH AGS43A42 2002 MODEL.I AM NOT ABLE TO LOCATE THE TORX screw under the filter compartment. There seems to be no screw at all. There is a float that I can remove but that does'nt solve the problem of drain. Can anyone help please.
thanks
joo.
Postby superfix » Fri Jun 03, 2005 7:56 pm
There is no access to pump impellor for user on that m/c i'm affraid.
Time to call an engineer.
superfix
Postby Guest » Sun Jun 05, 2005 6:42 am
hi Boro,
I have to share this news with you.I have found the access to pump and problem sorted (MODEL AGS43A42).It is at the bottom got to lean the appliance to the wall there are two screws to be removed at the front side of the bottom the lid comes off then u see the pump which can be removed, in mine I found a plastic chip jamming the propellor. It is working excellant now.Finally there is a float below the filter compartment has a magnetic clear side and grey side. which goes top? can u let me know please. I have grey up now. thanks for all the imformation from this site.I have saved £350 on a new dish washer, I have to cansel the order now.Thanks for all.
joo.
Postby superfix » Sun Jun 05, 2005 8:11 pm
Grey side up is correct.
what I meant by no customer access is you can't clear pump from the inside of the m/c. :wink:
superfix
Postby Jenn » Sat Jun 11, 2005 4:55 am
I am having troubles with a bosch dishwasher too (model Shu33a02uc/14) too. My problem is that the dishwasher keep trying to drain even though there is no water left (there is a bit in the sump, but well below the food filter). I have tried everything suggested here (i.e., cleaned the intake valve), with no luck - it is still trying to drain imaginary water. Is there a float switch or something that could be stuck on? I tried googling, but nothing is coming up. Any suggestions would be appreciated.
thanks,
Jenn
Jenn
Postby Martin » Sat Jun 11, 2005 7:29 am
Jenn,
Yes the problem is most likely a flooded baseplate in your case. Tip the machine backwards to drain off any water from it. It should work then, but you will need to call someone in your country to fix it correctly for you :)
Postby Guest » Sat Jun 11, 2005 4:57 pm
Thank you Martin! It worked. Do you know why the baseplate flooding and what a repairperson will have to do to fix it (is it a small job or a big job)? "My country" is Canad by the way :) .
thanks again,
Jenn
Postby Dave_Conway » Sat Jun 11, 2005 8:32 pm
It depends on what caused or is causing the leak Jenn really.
Not an easy one to answer to be honest.
Postby thesiteagent » Mon Jun 20, 2005 1:09 pm
Hi, Just happened apon your site as my dishwasher, hotpoint df61 was continually pumping. Followed the instructions to tip backwards and hey presto success. Question how on earth are you meant to see what could be leaking.
Mark
thesiteagent
Postby Martin » Mon Jun 20, 2005 1:53 pm
thesiteagent wrote: Question how on earth are you meant to see what could be leaking.
Good question!
Answer really involves an expert with a toolbox to find out for you :wink:
We have many such individuals dotted around the country that could investigate, just click Repairs@ to find one in your area :D
Postby DaveWad » Wed Jul 20, 2005 9:49 pm
Gents,
I have had exactly the same problems.
I have however removed the non return valve an there is still no flow.
Which pump is it that you think should be changed. I know the impellor is still working.
Any other suggestions?? :cry:
DaveWad
Postby clivejameson » Wed Jul 20, 2005 11:01 pm
Have you tried running the drain pump with its cover off for a few seconds then re-assembling?
If the pump is working (you can replace the rubber flap valve again) then it points to a blockage elsewhere.
First port of call would be the drain hose connection under the sink :wink:
Clive
Sharley Domestics Repair and Sales
Light travels faster than the speed of sound...which is why some people appear bright until they open their mouth.
clivejameson
PreviousNext
Users browsing this forum: No registered users and 14 guests
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 30 minutes)
