Hi - my dishwasher is constantly draining - float switch activated.
Have tipped out water and it works... kinda. however it's leaking so I suspect a leak is root cause.
My question is how can I access the underneath of the machine?
Have removed kickplate bit, and can only see a hole in the middle.
Do I remove the door? (seems peripheral to the problem)
Do I remove the sides?
Do I flip the machine and try to remove the bottom?
I am familiar with the door assembly having replaced PCB on similar machines, but don't want to waste time.
Found a nice diagram on http://www.bosch-home.co.uk/store/spare ... 45L02GB/13
but it's not too helpful.
Can you help??
