Bosh SG43E08GB/45 not heating water - FIXED but gone again!
Postby blenky » Wed Apr 05, 2006 11:58 pm
A month ago my Dishwashers instantaneous water heater failed. I heard a bang and it switched off. I replaced the fuse in the plug and although it cycled the water would not heat.
I got a BOSH engineer to fix it. He completely stripped the machine down to find the root cause without any success. He replaced the heater anyway and everything appeared OK. Tonight EXACTLY the same thing has happened. The fuse in the plug blew. When I replaced the fuse I find, as last time, the water is no longer heating
What are my rights here? Obviously the underlying fault was not found and by simply replacing the broken part has not solved the problem. Less than a month on I'm back at square one. Am I in my rights to demand the return, free of charge to put it right this time?
Thanks.
blenky
Re: Bosh SG43E08GB/45 not heating water - FIXED but gone aga
Postby Penguin45 » Thu Apr 06, 2006 12:18 am
Standard fault with these was underfilling - blows the heater in pretty short order.
You should have a guarantee on the repair work carried out, so get them back.
Postby blenky » Thu Apr 06, 2006 11:36 am
Penguin45 wrote:Standard fault with these was underfilling - blows the heater in pretty short order.
Thanks for the response.
So you are saying that the problem of underfilling should have been looked into and not just replacing the heater?
blenky
Postby Dave_Conway » Thu Apr 06, 2006 1:20 pm
To be fair to the engineer, it sounds like he did try to find an underlying cause but it wasn't apparent at the time, this happens with appliances on occasion.
As Penguin said, the work will almost certainly be guaranteed so a call to BSH Appliance Care should resolve the problem :D
Users browsing this forum: No registered users and 33 guests
In total there are 33 users online :: 0 registered, 0 hidden and 33 guests (based on users active over the past 30 minutes)
