candy water level system?
Postby leejohn » Wed May 25, 2005 8:49 pm
Can anyone advise me where the water level system is in a candy DWI160, and whats the best way to unblock it? Thanks
leejohn
Re: candy water level system?
Postby Penguin45 » Wed May 25, 2005 11:04 pm
Ok, seeing as no-one's coming back on this and I'm not personally au faite with this particular machine, a little general info to get you started.
The water level sytem works on the basis of the displacement of air, so there is a level switch (usually round), a skinny connecting hose, which in turn runs back to an air chamber. This and occasionally the hose can choke with food detritus.
You need to be able to access under the machine (Awkward - this is an integrated one, yes?) and find the level switch. Usually round in design with 3 or 6 terminals and the aforementioned skinny hose. Follow this back and the point at which it joins on is the collecting chamber. This may be a part of the sump (the area where the filters fit in the base), a fill matrix on the side of the machine, or occasionally a separate chamber attached to one of the hoses under the machine. Anyway, it needs to be cleaned out of any deposits, as the reduction in volume of the chamber affects the displacement of air and can cause flooding.
Power off of course before attempting any of the above.
If you are not confident, check Repairs@ or Directories for a UKW repairer in your area.
Users browsing this forum: No registered users and 49 guests
In total there are 49 users online :: 0 registered, 0 hidden and 49 guests (based on users active over the past 30 minutes)
