Have just registered having noted assistance from Penguin45 on error codes for this machine. Last autum ours stopped part cycle and started flashing seven times, pause etc. (just to be different). Also beeping. Couldn't get it to reset. Left it powered down till Christmas (don't use it that much anyway) meaning to have a go at fixing it then. Powered it back up and it was OK and worked till just after new year then same fault. Left it powered down again till a recent rainy day but this time problem still there. Took drain pump and softener off and checked for blockages etc. but all looks pretty clean. Washed filters and powered up OK. First programme ended prematurely and second attempted reverted to error code after short period. Have checked sensor in sump but all looks clean. Any thoughts or is it time to get rid?
