de dietrich VZ9996U1 Dishwasher
Postby safisofi » Wed May 07, 2008 4:40 pm
Door is not closing keeps popping out, called out british gas electrical repair man as I have a policy with them. Changed the latch system still not closing finally gave up saying that over time the frame gets bent hence need to get a new dishwasher ! Can't see how the frame got bent as the thing has never beeen moved or tampered with. Would appreciate any thoughts or any contacts in Birmingham who can fix it as not a lot of repair people know about this integrated dishwasher.
thanks
safisofi
Re: de dietrich VZ9996U1 Dishwasher
Postby Penguin45 » Wed May 07, 2008 8:51 pm
Check that door opens no more than 90 degrees. If it's drooping floorwards, the hinges are bent and the door latch cannot hold the extra tension generated by the door not pulling up properly.
Use the repairs@ link on the left for a local engineer - if you get no results under De-De, try Brandt or Diplomat for the brand.
Postby malcstercat » Fri May 23, 2008 9:27 pm
The door cords are probably broken-they conect the door springs to the door hinge and the plastic eyes break at each end. Have a look under the door left & right and if you can see any white string hanging down that is the problem.Mal.
malcstercat
Postby Penguin45 » Fri May 23, 2008 11:44 pm
Broken door strings will not stop the door from closing - they will allow the door to drop uncontrolledly and bend the hinges............
Postby DentedPorsche » Sat May 24, 2008 3:53 pm
From what you've learned here I'd advise you to call British Gas and request a different engineer attend the fault. Tell them that you've been advised bent hinges would cause this problem.
If the door does drop below the horizontal, show the engineer and tell him that you've been told that this is caused by bent hinges.
If you've already had a contribution from British Gas toward a new dishwasher, call customer services and complain.
DentedPorsche
Users browsing this forum: No registered users and 17 guests
In total there are 17 users online :: 0 registered, 0 hidden and 17 guests (based on users active over the past 30 minutes)
