by PHILIP FANTHAM » Mon May 09, 2005 12:38 pm
I have a diplomat adp8322 14 months old. Undr warranty it has already had a replacement thermerstat. The dishwasher doesn't seem to be cleaning properly at all. After its cycle there is on most of the crookery etc a film of food. When you open the door you can see that the grey pipe that comes from the back of the machine to the base is out of its socket. It will go back in but after every wash it comes out again. A repair man has looked at it and says I need a new motor. I can't see how it can need a new motor after just over a year. It must be to do with this pipe. Any Ideas?
PHILIP FANTHAM
by Dave_Conway » Mon May 09, 2005 2:21 pm
The grey pipe feeds water to the upper spray arm which is causing this problem, although if an engineer has diagnosed the circulation motor this may well be the case as well (two faults).
Is the water spraying OK from the lower spray arm (lower basket dishes clean, powder/tablet dissolved) ?
by Guest » Mon May 09, 2005 6:01 pm
The lower spray arms seem to work, though on occassion not every time I have noticed that the tablet has not disolved. When the cycle is finished the contents are not always dry especially glasses. I have tried it agfain today and again it washes to a degree and again the grey pipe has come away from the base.
by DentedPorsche » Mon May 09, 2005 8:12 pm
It's a known problem on the Whirlpool dishwasher. Only cure is a new sieve cover / cover for the pipe to plug into. The bottom spray arm won't wash properly either with the pipe out as most of the water escapes instead of going through the spray arms.
Once it's in place it will wash ok again, but make sure the spray arms aren't blocked.
As to the drying problem, as soon as the program is finished you have to open the dishwasher door to vent the steam (except on turbodry models). If you don't the steam just condenses back onto glasses and crockery. (They don't dry plastic items either).
DP
DentedPorsche
- Appliance Forum Veteran
by Guest » Tue May 10, 2005 10:39 pm
Great Thanks for the help.
- DIPLOMAT ADP8322
by acestu » Tue Jun 21, 2005 6:18 pm
- 1030 Views
- Last post by Guest
Tue Jun 21, 2005 7:11 pm
- Diplomat ADP8322
by deb12 » Wed Oct 26, 2005 8:35 am
- 4 Replies
- 1099 Views
- Last post by DentedPorsche
Wed Oct 26, 2005 6:18 pm
- Diplomat ADP8322
by Whiskyman » Wed Dec 21, 2005 10:27 pm
- 7 Replies
- 1947 Views
- Last post by Whiskyman
Wed Jan 04, 2006 8:43 pm
- Diplomat ADP8322
by sibourne » Thu Feb 02, 2006 12:18 pm
- 4 Replies
- 1488 Views
- Last post by maltheviking
Thu Feb 02, 2006 6:58 pm
- Diplomat ADP8322
by Jacks » Wed Mar 08, 2006 10:43 pm
- 996 Views
Thu Mar 09, 2006 12:12 am
Users browsing this forum: Google Adsense [Bot] and 15 guests
