Diplomat ADP8332 - leaking into drip tray
Postby carmenlouise » Sun Jan 11, 2009 2:25 pm
Hello, have sought help from you guys beifre with success - so thought I would ask for your help again please - another simillar prob!
F2 code then FA - front off, panel down - drip tray full of water - mopped up and started cycle again and observing two "leaks" one from left and one from right side of white plastic circular area(seems to be ??base of sump) - left side appears to be result of slow overflowing on this side of area and right hand side appears to be coming from a small square ares of the plastic cylinder. Does this make any sense!!!????
Question is - any idea what causing this and is it a huge prob - prob need to call engineer but want to know if worth it -
its working again, but only matter of time til fills drip tray and realarms. Take it its not normal for this leak.
thanks in advance
sorry about amateur language - but have no idea of the correct technical terms
cheers
carmenlouise
Re: Diplomat ADP8332 - leaking into drip tray
Postby karv » Tue Jan 13, 2009 11:33 pm
never had one of these with two leaks before, i,ve had motor leak and spray everything , that could give u false leaks , i,ve had sump leaking where it drops to far on 1 side could be screw losse or new sump, only ever had an over fill from water comming back in from sink or valve letting by but that was when its was turned of.
my personal view is u unlikely to have 2 leaks from 2 diffrent things , unless u can be sure why yourself u will need to get a engineer.
karv
Users browsing this forum: No registered users and 10 guests
In total there are 10 users online :: 0 registered, 0 hidden and 10 guests (based on users active over the past 30 minutes)
