by HughJampton » Wed Jul 18, 2012 11:20 am
Hello,
My Hotpoint FDM550 dishwasher kept blowing its plug fuse at random intervals. I traced it to blackening on the mains suppressor which I replaced.
All was ok for two weeks but now the fuse is blowing again. The suppressor is now blackened like the old one. When I change the fuse and plug it in with the machine lying down so I can see inside, there is sparking in the suppressor as if it's shorting out although I can't see any obvious leaks where moisture is getting in. Could I have got two faulty suppressors on the trot?
Any thoughts would be much appreciated before I scrap it for a new machine.
Cheers,
Mike.
HughJampton
by Seamy » Tue Jul 31, 2012 7:48 am
Don't scrap the machine, it would work without a suppressor but its not advised, they are to prevent interference/spikes with electronic devices like hi-fi, tvs radio etc.
Its not an expensive part but they are prone to blowing.
Seamy
- Appliance Forum Veteran
by the q spark » Tue Jul 31, 2012 8:19 pm
Has the mains lead got a moulded plug? if it has change it to a normal rewirable plug and change the suppressor again, the moulded plugs can develop internal faults and can cause suppressor faults its more common than you would think! "Q"
the q spark
- Appliance Forum User
by HughJampton » Thu Aug 02, 2012 2:04 pm
the q spark wrote:Has the mains lead got a moulded plug? if it has change it to a normal rewirable plug and change the suppressor again, the moulded plugs can develop internal faults and can cause suppressor faults its more common than you would think! "Q"
Good tip, thanks very much. Yes the plug is moulded, I'll give it a try.
HughJampton
by A1engineer » Thu Aug 02, 2012 3:15 pm
Had loads of bekos and hja(howden) dishwashers with dodgy moulded plugs, as a rule if its low i just cut plug off and change it
"if you put you mind to it, you can accomplish anything"
A1engineer
- Dishwasher suppressor!!
by Peabody » Tue Jul 04, 2006 12:29 pm
- 4 Replies
- 1014 Views
- Last post by Peabody
Wed Jul 05, 2006 8:03 am
- Dishwasher tripping fuses
by redwan » Mon Mar 23, 2009 1:38 pm
- 788 Views
- Last post by redwan
Tue Mar 24, 2009 1:05 pm
- Smeg Dishwasher Mains Filter/Suppressor
by worthy31 » Sat Sep 19, 2009 10:15 am
- 731 Views
- Last post by don
Sat Sep 19, 2009 11:03 am
- Dishwasher Blowing Main Fuse
by Santorini » Sat Apr 06, 2013 1:29 pm
- 87 Views
- Last post by electrofix
Sat Apr 06, 2013 1:47 pm
- Zanussi Dishwasher DA6152 Blowing Main Electrical Fuse
by Santorini » Fri Mar 29, 2013 3:37 pm
- 117 Views
- Last post by Martin
Fri Mar 29, 2013 4:49 pm
Users browsing this forum: No registered users and 64 guests
