Help!! Dishwasher dead
Postby angel50 » Thu May 03, 2012 10:48 pm
Redid our kitchen floor before dishwasher moved out was working fine moved it back- plugged it nothing! What have I done to it? No lights no sound nothing it isn't the fuse in the plug or the main fusebox. Anything simple it could be? Wierdly my iron did the same thing in a different room and different socket today. It worked again after unplugging it taking fuse out and putting same fuse back in?! :? Oh its a Bosch Excel
angel50
Re: Help!! Dishwasher dead
Postby Allsorts » Fri May 04, 2012 7:01 am
Check your wall socket has power.
Also, with regard to the iron.. close the holdings for the fuse slightly.. a loose fuse can cause surges and fires.
Allsorts - Where Recycling Means Being Natural
Supporting http://www.findmyrecycler.co.uk - connecting waste to recyclers
We are looking for more recyclers
Get a FREE listing on the database - Contact Us at Find My Recycler
Allsorts
Postby angel50 » Fri May 04, 2012 6:47 pm
Thanks you were right pulled dishwasher out again plugged into alternative socket dishwasher is fine! Socket is dead- is loose wire in it most likely cause?
angel50
Postby Allsorts » Sat May 05, 2012 6:06 am
Yes a loose wire is the most proberble cause... and again, I would suggest getting it seen to as Loose Wires Cause Fires.
If you are going to attempt it yourself
:zap: TURN OFF AT THE CONSUMER UNIT FIRST :zap:
Allsorts
Postby angel50 » Sun May 06, 2012 4:37 pm
Thanks am not going to do this one myself as socket is not working and i can't be sure correct fuse in consumer unit is off (will get an electrician) Turns out this was an old socket and not the one it was plugged into before which is in unit next to it and involves tricky threading!!!
Not having any luck with just putting this stupid dishwasher back. as its now sprung a leak from where the inlet hose meets the appliance. Wet new floor!!! :( Grrrrr! I'm also worried it seems to be dripping underneath LHS as you face the unit and about 6 inches back from front - any ideas? Am really praying its still wet from inlet pipe puddle- but it does seem bit odd its just dripping there also is it normal for them to have virtually no floor clearance underneath?
angel50
Postby Allsorts » Sun May 06, 2012 7:31 pm
May I suggest that one of the appliance engineers would be able to help you if you click here Find An Engineer
Allsorts
Users browsing this forum: No registered users and 13 guests
In total there are 13 users online :: 0 registered, 0 hidden and 13 guests (based on users active over the past 30 minutes)
