Hotpoint BFi62 - Error Code (First LED flashing)
Postby simonplummer » Sun Jun 04, 2006 1:10 pm
Hi, Need help as hotpoint can't!!
My Hotpoint BFI62 decided to stop working - when the program is selected and the door closed it sounds as though it is a bout to start up but does not appear to kick in (no water sounds) there is a short beep then when the door is opened the first light is flashing constantly. There is no water inside the machine or the sump - i placed a couple of cups of water in the sump - ran the program again and the water was gone - this would appear to prove the drainage is ok. I have checked all the water supply's etc they appear to be OK. Any ideas what the flashing light means - i called hotpoint for the code meaning as it says in the book but they said they couldn't tell me!!! :x just a tad frustrating - any help would be greatly appreciated as this machine stopped domestics with my mrs!! :wink:
simonplummer
Re: Hotpoint BFi62 - Error Code (First LED flashing)
Postby gegsy » Sun Jun 04, 2006 2:18 pm
Hya simon
You havent been overlooked. Im sure iadom will sort you when he logs in later.
Greg
gegsy
Postby iadom » Tue Jun 06, 2006 12:01 am
Hi, sorry for not spotting this before, :oops: problems with an elderly relative.
First led flashing means you have a flooded base. Depending on how well or otherwise :cry: your dishwasher was installed, pull the machine out and after removing the mains plug, place a couple of towels around the base and tilt the machine, either backwards or to one side. If water runs out from underneath then that is the reason for the fault code.
You can try the machine again, but if the fault returns then it would suggest that you have an internal leak that needs investigation. Overflow into the base can also be caused by using 3 in 1 or 4 in 1 tablets together with rinse aid. Separate detergent, rinse aid & salt in all but very soft water areas or something like Fairy Active Bursts are a better.
Postby simonplummer » Tue Jun 06, 2006 11:45 am
Thanks for this peeps! I am away at the moment but will try when i get back. Thanks again! i will let you know how i get on
simonplummer
Postby simonplummer » Wed Jun 14, 2006 4:24 pm
Hi, Just to let you know this worked a treat - dishes clean - no arguments!! thanks a lot for your help! Apologies for the delay in reply.
simonplummer
Postby iadom » Wed Jun 14, 2006 9:34 pm
Very kind of you to let us know the outcome. Remember to have the machine looked at if the fault returns and avoid 3 in 1 or 4 in 1 tablets.
Users browsing this forum: No registered users and 20 guests
cron
In total there are 20 users online :: 0 registered, 0 hidden and 20 guests (based on users active over the past 30 minutes)
