Machine stops before final heat cycle with buttons 4 & 6 flashing (fast & dry + delicate)
After reading a few hotpoint posts (different model numbers) it seems as if my problem may be the same.
Advice given was heater or PCB fault.
If the heater works ie heats up water (as in this case) could this still be the problem or will it be the PCB.
Advice on how to proceed would be very welcome.
serial number 612088369
Thanks in advance
Kevin
