The "check water supply" indicator is on and the dishwasher is making gurgling noises as if it is trying to empty with no water in. Sounds like it is drawing in air!
I have checked the filter in the water supply pipe and it is clear. I have also checked the water pressure to this control tap and it is OK.
If I pull out the machine and tilt it water comes out from underneath but I don't know where from.
If I mop up the water in the base that appears to be activating the flood float the machine is ok again until when it starts filling water appears again until the float is activated.
I have taken off the side panals and cannot see where the water is coming from.
Where are the most likely places it will leak that are easily accessable?
Any ideas how I can overcome this problem?
PLEASE!!
