by Roaster323 » Fri Oct 30, 2009 3:52 pm
Had this excellent dishwasher for about 18 months now.
Usually run it on the low heat / short time setting. When I start it, the soap block (finish) drops into the bottom of the machine quite soon after the cycle starts (minute or two) and can sometimes be seen part dissolved in the bottom of the machine at the end of the cycle.
Is this normal?
The machine is still under Neff extended warrantly
Many thanks
Keith
Roaster323
by nomadPaul » Fri Oct 30, 2009 7:04 pm
How much water is there is the bottom of the appliance once it starts washing ? It should almost cover the base and should reach the bottom of the salt pot lid.
Does it make any funny 'donking' noises when filling ?
Check your spray arms are clear too.
Finally.....don't use the quick wash so often. It can lead to a blockage in the pipe that leads into the tub and can cause low water levels.
nomadPaul
- Appliance Forum Veteran
by superfix » Fri Oct 30, 2009 10:59 pm
Don't use quickwash and tablets together, there is neither enough temperature or time to disolve the tablet properly.
On a quickwash prog the dispenser will actuate a couple of minutes after the m/c has stopped filling.
If you want my advice, I would suggest using seperate detergent, rinse aid and salt, also use a higher temperature wash.
I wanna be sedated
superfix
- neff s5943x2gb leaking
by ashley600 » Tue Jan 03, 2012 1:22 pm
- 5 Replies
- 384 Views
- Last post by ashley600
Wed Jan 04, 2012 4:03 pm
- Neff Intergrated Slimline Dishwasher D5946
by nivlem » Sun Jan 17, 2010 6:06 pm
- 388 Views
Sun Jan 17, 2010 7:50 pm
- SlimLine Dishwashers
by Woolabrawonga » Thu May 05, 2005 6:28 pm
- 5 Replies
- 1280 Views
- Last post by Huest101
Fri May 13, 2005 8:03 am
- Diplomat (slimline)
by M1 » Mon Jan 29, 2007 10:04 pm
- 906 Views
Thu Feb 01, 2007 8:30 pm
- slimline dishwasher
by clarky67 » Thu Apr 26, 2007 5:56 pm
- 946 Views
- Last post by clarky67
Thu Apr 26, 2007 8:06 pm
Users browsing this forum: Majestic-12 [Bot] and 31 guests
