This may seem daft but i thought i posted this days ago but i can't find it?
To cut long to short. A fisher paykel dishdrawer that f1's I found some corrosion on the very corner of the mains/flood pcb cleaned it up and the f1 went away tested it and it was fine got a call back it had gone again so i checked everything found no problems and it just worked... So I left then 30mins later I get another call, it's gone f1 again...
Can any one help as I'll be getting a call any time off this one.
Also how does the machine sense the water level as when you switch off full of water and start it up it emptys really slow but leaves loads in the fills up even more yet when it f1's it emptys fast
