Smeg Dishwasher constantly filling with water!
Postby Doozergirl » Tue May 05, 2009 9:09 am
Hoping someone can advise - bit of a long story!
We moved out of a house three years ago - when we moved, my husband couldn't get the inlet water pipe off the plumbing fixing so he had to cut the pipe. Fast forward three years... and he's decided to put the dishwasher back into service! He's done a bit of a quick fix on the pipe using a new end fixing, some 10mm copper pipe and some jubilee clips.
Well, as soon as you turn on the water pipe, the machine just fills with water from the bottom. Luckily the dishwasher when switched on, drains the water out! It seems to be responding to being put on an actual wash - makes the right noises etc but the water is coming from the wrong place!
There is also a random black cable that is hanging out of the back of the machine - is this important?! It's a DWF614SS if that helps any. I'm thinking he's chopped off something that regulates the water supply?
Thanks in advance for any replies.
Doozergirl
Re: Smeg Dishwasher constantly filling with water!
Postby johnsdad » Tue May 05, 2009 7:21 pm
You've cut off the aquastop hose assembly off (it had a square plastic block at the end containing solenoid valves). It would need replacing as a complete item. Water and electrical connections are in base of appliance - plug out or call an engineer
johnsdad
Postby Doozergirl » Tue May 05, 2009 9:10 pm
Thank you very much! I was reading about the aquastop and did wonder if that was what it was.
Would H be able to replace it with any ease - I think the back has to back taken off doesn't it? If it's easy then would someone be able to help me locate the right part to purchase?
Or would it really be better then to call an engineer? I guess I'm just happy if I don't need to buy another dishwasher!
Doozergirl
Postby johnsdad » Wed May 06, 2009 7:51 pm
Connections accessed under base tray. Try spare parts area on this site, or parts available from smeg service. PULL OUT PLUG before attempting any repairs.
johnsdad
Postby Penguin45 » Wed May 06, 2009 8:32 pm
Aqua-stop fill hose for this machine is p/no 758972367. An email to spares@ukwhitegoods.co.uk will get things moving for you.
JD, please contact admin@ukwhitegoods.co.uk and ask for trade access.
Penguin45,
Moderator.
Postby Doozergirl » Thu May 07, 2009 5:37 pm
Thanks very much guys, most helpful!
Doozergirl
Users browsing this forum: No registered users and 29 guests
In total there are 29 users online :: 0 registered, 0 hidden and 29 guests (based on users active over the past 30 minutes)
