by col-mac » Mon May 26, 2008 6:47 pm
this dishwasher developed a fault after being left unused for 6 weeks. Now when a program is selected the drain pump runs for 30 seconds then the machine fills for 10 seconds then it bleeps and starts to drain, if left the drain pump runs for 30 seconds and stops the alarm continues to sound.
this is the same fault as on a diplomat which was not used for 6 months
I disconected the diaphram switch, made no difference.
I disconected the pump also no difference.
HELP...
col-mac
- Appliance Forum User
by Penguin45 » Mon May 26, 2008 7:19 pm
Ignore the beeps, count the pattern of the flashing start lamp.
by col-mac » Mon May 26, 2008 7:37 pm
start lamp flashes continuously
col-mac
by Penguin45 » Mon May 26, 2008 7:48 pm
Continuous flashing is F1; the temperature sensor (NTC) is not working correctly. It's the probe sticking through the base of the sump, under the filters and is a twist fit from underneath.
Replacement available
HERE.
Power off before going in..........
by col-mac » Thu May 29, 2008 12:34 pm
I got this wrong, when I recheked there are 6 flashes then a pause
col-mac
by Penguin45 » Thu May 29, 2008 7:00 pm
THIS should be what you need to know.
- whirlpool adg7550
by col-mac » Wed Feb 10, 2010 5:30 pm
- 723 Views
- Last post by col-mac
Thu Feb 11, 2010 1:30 pm
- Whirlpool ADG7550
by properbroke » Sat May 07, 2011 3:29 pm
- 496 Views
- Last post by kwatt
Sun May 08, 2011 9:57 am
- whirlpool adg7550 8 flashes
by geoffatno6 » Sat Sep 06, 2008 12:39 pm
- 570 Views
- Last post by geoffatno6
- whirlpool adg7550 4 flashes
by BlueBilly » Mon Sep 07, 2009 8:07 pm
- 530 Views
Mon Sep 07, 2009 9:11 pm
- whirlpool adg7550 problem
by razor414 » Sat Dec 19, 2009 3:51 pm
- 4 Replies
- 957 Views
- Last post by razor414
Wed Dec 23, 2009 10:12 am
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 14 guests
