whirlpool dishwasher
Postby colinread » Thu Jan 18, 2007 2:45 pm
Model No. DWF 415. This is a brand new unit and also new plumbing. it fills up with water then the light flashes. If you push the button in and hold it empty the water OK. The water inlet is attached to whats called a `water stop` this is positioned near the floor horizontal. could this be the problem ?. Also ive only got cold water supply is this ok ? Any helfp would be great.
colinread
Regular Appliance Forum User
Re: whirlpool dishwasher
Postby Fairdeal » Thu Jan 18, 2007 8:21 pm
How many lights and which lights are flashing?
Also if you can give the full model or the long 85??? no.
If you say it is filling up water(and water is in the dishwasher) and then stops taking water in then the spray motor should kick in.
Fairdeal
Postby colinread » Thu Jan 18, 2007 8:54 pm
thanks for reply `fairdeal` its verry basic a program selector knob for 0, program1,2,3,4 and then a single button for start and one small light ( green) thats it its for Ikea from Whirlpool. i spoke with tech. @ whirlpool today they said to hold start button in for 6 seconds, leave for 30 seconds and then press start button once. the machine ran then stoped with green ligt flashing. hope this helps.
colinread
Postby Penguin45 » Thu Jan 18, 2007 9:39 pm
Is there a pattern to the start light flashing; ie 1-2-3-4-pause-repeat?
Postby clivejameson » Thu Jan 18, 2007 9:43 pm
Sounds very much like a seized wash pump...even had a brand new Bosch with one this week. The cure is easy....the pump just needs a helping hand to start for the first time, unfortunately this is not a diy job particularly as it's under guarantee?
Incidentally the light should flash 5 times then pause if this is the case.
Clive
Sharley Domestics Repair and Sales
Light travels faster than the speed of sound...which is why some people appear bright until they open their mouth.
clivejameson
Postby colinread » Thu Jan 18, 2007 10:02 pm
My wife bought it in 2003 and its been standing in garage until now ! Exstension to build with new kitchen etc.
Light flashes 1-2-3-4-5-6-pause-repeat.
If you open bottom is full with water, then if you hold start button in it pumps water out.
If its the pump are they similar to a washing machine etc.
colinread
Postby colinread » Thu Jan 18, 2007 11:17 pm
Service No. 8545 415 15750
I found some info on web on 851175001810 with regards to failure code,indication in test program when a failure occurs.....
It seems to indicate F6 water tap closed----
a, water tap closed (seems ok )
b, water inlet hose blocked ( seems ok )
c, water inlet valve ( WV1 ) defective. ?
What do you think.
colinread
Postby clivejameson » Fri Jan 19, 2007 9:22 am
6 flashes could also indicate a problem with the system that controls the water level which seems more likely as the machine has obviously taken water onboard.
This is often caused by food residues in the system but as the appliance is brand new then is engineer time i'm afraid.
The good news is it is under guarantee so it won't cost you anything to call the manufacturer out to sort it for you. :wink:
Clive
clivejameson
Postby colinread » Fri Jan 19, 2007 10:47 am
Thanks for input guys.
I spoke with whirlpool they want £ 70.00 odd. to send engineer out as the item was purchased in Jan 2003.
They told me to speak to IKEA after I mentioned about the sale act 1979 that all goods should be good for 6 years.
IKEA said that they give a 90 day ! Then a year with whirlpool !
I mentioned about the 1979 sales act and they have loged my information and will call me back in 12 working hours.
I will see what happens.
colinread
Postby clivejameson » Fri Jan 19, 2007 1:02 pm
If IKEA refuse to budge then you could try the link below for a local engineer...most if not all will have a smaller call out charge than £70!!!
Besides...it will likely be something minor...the inlet regulator's prone to problems and the fact that it has been unused may mean it needs a techincal adjustment (judicious thump with a flat hand!) to revive it :wink: This part is located inside a water chamber inside the cabinet so not a diy job unless you are confident.
If you have a go yourself then you must unplug before doing anything
:zap:
Clive
clivejameson
Postby colinread » Fri Jan 19, 2007 4:02 pm
I took the side panel off to look at water chamber, did a flat hand hit with no sucess. When you start program, machine fills up with water just up to the point of door seal- then the green light starts flashing!. after its got to this stage should the water be pumped up to the spray arme etc. ?
colinread
Postby colinread » Mon Jan 22, 2007 5:37 pm
IKEA made contact and wont move on there 90 days- whirlpool 12 months !
I take it after the water has put in its quota a pump must turn on to spray water ?
Any help will be great.
Tried the engineer route but none in my area. Chippenham,Wiltshire.
colinread
Postby colinread » Tue Jan 23, 2007 2:03 pm
can anyone tel me where the `water inlet valve` is located ?
colinread
Postby Washman » Tue Jan 23, 2007 2:42 pm
Machine is overfilling if water gets to bottom of door. So engineer time to sort it out.
Mike
Washman
Postby colinread » Tue Jan 23, 2007 9:25 pm
Where is the flow meter ?
colinread
Next
Users browsing this forum: Google Adsense [Bot], okidokicoki and 45 guests
In total there are 47 users online :: 2 registered, 0 hidden and 45 guests (based on users active over the past 30 minutes)
