by annpixie » Wed Jan 09, 2008 10:39 pm
Dishwasher came to end of programme, but start light stayed on in flashing mode.So I cleaned the filter and held the start button pressed in for 2 seconds as per instructions in user guide, I should then have been able to start a new programme, but the start light was still flashing and dishwasher will not work at all.Any ideas? Model is DWF415S TYP NGPM , unfortunately I don,t have the service code number the plastic strip with it on is missing.
annpixie
by Penguin45 » Fri Jan 11, 2008 12:55 am
To cancel the programme, hold the button down until it goes 'bip'. Then shut the door and wait for the drain pump to stop running. If the lamp is just doing a steady continuous flash, you most likely have an NTC (temperature sensor) failure.
by annpixie » Fri Jan 11, 2008 11:11 am
Thanks for advice, tried holding button in but no bip.Light still flashing it flashes twice pauses then flashes twice again pauses and so on.Where abouts is the temperature sensor situated, how would I go about fixing it, or is this too complicated for diy.How do I test the component to check if it has failed.Thanks
annpixie
- Ikea DWF B10W Constant Bleeping and Flashing Start Light
by bioman001 » Fri May 04, 2007 8:31 pm
- 17 Replies
- 3748 Views
Sun Aug 12, 2007 8:54 pm
- Whirlpool dishwasher G2P DWI flashing light
by 1longpole » Tue Jul 29, 2008 8:06 pm
- 1795 Views
- Last post by 1longpole
Wed Aug 06, 2008 9:50 pm
- Whirlpool ADP903 Dishwasher Flashing light
by Hello » Sun Jul 11, 2004 10:56 pm
- 1901 Views
- Last post by Guest
Thu Jan 01, 1970 12:00 am
- Whirlpool creations dishwasher - flashing light?!!
by iesugrist » Sun Jan 23, 2005 8:11 pm
- 4 Replies
- 1301 Views
Sun Jan 23, 2005 8:30 pm
- whirlpool g2p gwi dishwasher - light flashing 3 times
by DOVOBET » Tue Dec 29, 2009 9:50 pm
- 723 Views
Wed Dec 30, 2009 12:50 am
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 44 guests
